PART 2 ARGHH!
Discussion in 'XJ Technical Chat' started by guzzijohn, Dec 6, 2008.
  1. guzzijohn
    guzzijohn New Member
    :D ARRGHH? Part 2-650 engine completely stripped-nothing too bad but for broken chain guide block and loose chains. Have line on '82 750 maxim mill for cheap. A pig in a poke but will pull valve cover and sump to eyeball. Mine has minor rust pitting in bores and slight scoring of pistons from that but usable. Good winter project(W.C. below 0 now!)prepped tank for coating today. Still haven't figured out where loose needle bearings came from-they're about 1X3 mm?? Found 6 or so in pump screen. :? GUZZIJOHN
  2. wizard
    Still haven't figured out where loose needle bearings came from-they're about 1X3 mm?? Found 6 or so in pump screen. GUZZIJOHN
    Starter motor bearing ???
