Parting out 83 XJ750 Seca, lot of good stuff left
Discussion in 'For Sale, Trade/Swap, Wanted' started by baz666, Apr 6, 2010.
  1. baz666
    baz666 Member
    Washington, DC
    Lots of good parts available. I'm keeping prices low. Let me know what you need.
    thanks,
    baz
  2. skills4lou
    skills4lou Member
    Dillon, MT
    I need a front turn signal. My bike has black plastic for the housing, not sure if the new model is black or chrome.
  3. baz666
    baz666 Member
    Washington, DC
    I'll check and see when I get home tonight and let you know but I'm pretty sure I've got something that will work. I'll take a photo and post it.
    I guess something like $10 plus shipping would be the price and its small enough to put in a padded envelope to keep shipping cost down.
    thanks,
    baz
  4. KVB_650
    KVB_650 Member
    Quebec
    Hi,
    I am looking for the chrome/plastic Yamaha logo that goes across the front of the two forks, just under the fog light.
    Ken
  5. brent_bastien
    brent_bastien Member
    Commerce mi
    front fairing
  6. baz666
    baz666 Member
    Washington, DC
    Sorry, no chrome/plastic Yamaha plate
    and no front fairing.
    Basically, the good stuff includes the handlebar switches and do dads, CDI unit, R/R, stator/rotor, solenoid, carb bodies without diaphrams, tail section including brake/tail/license light and grab bar, side covers but they need work (a few cracks and a missing mounting bung), tank (slight dent on front left corner and internal rust), wheels, frame, some cam parts.
    The engine was run with muddy water mixed in with the oil, then left to sit for a long time, making any steel engine parts pretty much useless. Aluminum engine parts are okay, such as the cyl. head,which could be stripped, cleaned and re-used, cam chain guides are good, cam sprockets are good, valve cover is good, pegs are in pretty good shape.
    But all else is shot, including calipers, discs, forks, shocks, seat, gauge set, tires, wiring harness, etc.
    If there's anybody in Southern Ontario and wants the good parts and rolling chassis, sending me a PM and we can work out a very good deal for the whole kit'n'kaboodle.
    thanks,
    baz
  7. Brodie
    Brodie Member
    How much for the starter solenoid baz?
  8. junkmn
    junkmn Member
    Colorado
    HOw about the carb intake boots? The intake side not the airbox side.
  9. padre
    padre Member
    Lawton, Oklahoma
    I've got an 81 750Seca with 36mm air forks, I need the air joint (yoke) that slides over the fork tube beneath the top 1/2 of the triple tree, ya got one?
  10. baz666
    baz666 Member
    Washington, DC
    I'll check what shape they're in and let you know.
    thanks,
    baz
  11. baz666
    baz666 Member
    Washington, DC
    Sorry, solenoid's gone.
  12. seaguy
    seaguy Member
    Coastal,AL
    Baz you got any stock 750 HSC32 jets ? I think they are 120/40
  13. baz666
    baz666 Member
    Washington, DC
    REPLIES FOR QUESTIONS ABOUT: JETS, CARB BOOTS, AIR JOINT (YOKE), FRONT TURN SIGNAL
    JETS
    Sorry, the ones that were in the bike are 107.5 and 43. I've also got a set of 102.5
    CARB BOOTS
    Also, about the carb intake boots. The rubber coating on the side that attaches to engine has come off in a few spots, around where the bolt goes through the bolt hole. Underneath the rubber is an aluminum frame and its showing through. I guess you could use some of that black liquid gasket stuff to cover it so there's no air leak. I'm just not sure how the liquid gasket would react to the heat and air/fuel mix going past. I think the liquid gasket is made to take a certain amount of heat and oil but I don't know how it would react to be exposed to the air/fuel mix.
    If you're interested, maybe you can look into it and let me know if you want them. As they are, I'd say $25 including shipping.
    AIR JOINT (YOKE)
    I have the piece you're looking for but one of the air valves appears to be jammed and won't accept any air. If you still interested, you can have it for $30 shipped, mostly due to the weight.
    FRONT TURN SIGNAL
    Yep, I've got one, including the rubber stalk and wiring. It functions fine but there are couple of very small cracks in the orange lens. Not broken or pieces missing, just hairline fractures. So if you want it, I'd say something like $15 incl. shipping.
    Here's the main parts remaining that are in very good condition unless otherwise indicated. All prices incl. shipping to US or Canada
    CDI box $70
    Reg/Rect $45
    Headlight with chrome surround $50
    Clutch side switch gear $40
    Starter $60
    Carb bodies without diaphrams $50 (throttle shaft seals leaks, choke shaft seals leak, good for rebuilding and needs diaphrams)
    Rear tail section incl. brake/tail light, plastic, grab bar, good cond. $70
    Seat $70 (has one cross-wise split, needs recovering but foam/seat pan very good)
    Front fender $50 (good structurally but scraped up, needs refinishing)
    Pretty much all else is in rough shape and needs rebuilding.
    There are some other bits and pieces I can't recall off hand so if there's something specific you need, just ask.
    thanks,
    baz
  14. junkmn
    junkmn Member
    Colorado
    Yep, I am still interested in the intake boots. They sound better than the ones I have. Message me on how you want payment.
  15. KennyNapalm
    KennyNapalm Member
    Calgary AB
    can i please have a pic of the gauge set? do you know if they will work with a xs400 maxim? prolly hey?
  16. JMBishop
    JMBishop New Member
    Do you still have the tank?
  17. BRSM
    BRSM New Member
    How much do you want for the relays - Starter circuit cut-off, side stand, starter solenoid (starter relay), head lamp, flasher, and diode block?
    Are the carb bodies hitachi or mikuni?
    I am also looking for the little rectangle Yamaha sticker that goes over the handlebar covers (it's about 2" long and .5" high)
    Throttle cable/clutch cable?
    Neutral switch/clutch switch?
  18. baz666
    baz666 Member
    Washington, DC
    Sorry, gauge set is gone and I'm not sure it fits the XS400. Doesn't that bike have 2 indivdual gauges for speedo and tach? The XJ750 Seca has a single gauge box with everything in there, including that wacky 'computer'.
  19. baz666
    baz666 Member
    Washington, DC
    Yep, I've got the tank but it's got a dent/laceration at the front leftside top corner and the inside is quite rusty and would need a clean up.
    Because of the size, etc, I'd have charge $75 including shipping to US or Canada.
    thanks,
    baz
  20. baz666
    baz666 Member
    Washington, DC
    Neutral/clutch switches (do you mean handlebar or foot shifter?)
    Solenoid, gone.
    Diode block burnt (doesn't stop current from returning).
    Side stand circuit removed before I got bike.
    Rectangular Yam sticker, removed before I got bike.
    I have:
    Starter cut off switch is good but right-hand handlebar switch assembly missing starter button. But does come with throttle assembly, cable and rubber handlebar grip.
    Clutch cable and left hand handlebar switch gear, good.
    Flasher, good.
    Carb bodies are Hitachi
    Head lamp with chrome surround, good.
    ENTIRE PACKAGE, due to weight of carb bodies,
    $80 incl. shipping anywhere in US or Canada.
    thanks,
    baz
