Parts HELP!
Discussion in 'Hangout Lounge' started by smileyseca, Nov 26, 2012.
  1. smileyseca
    smileyseca New Member
    Colorado
    I'm still new to the XJ and my Seca needs a lot of TLC. I'm looking for a few parts and I've scoured ebay and some craigslist adds.
    Does any one know where I can get the right and left side engine covers?? I've found some in decent shape, but nothing that is scratch free and no pairs. I need both sides. They can be smooth or have the YICS on them, it doesn't matter to me. I'm going to black them eventually any ways.
    I also need a front right brake caliper and rotor. The one I have was seized up and then crowbared off by the previous owner, leaving it almost useless. Seems one of the pistons decided it was a good day to die. The inside surface of the caliper is all chewed up now and not really useable.
    Thanks for any help
  2. osprey1000
    osprey1000 Member
    Annapolis, MD
    Calipers try XJ4Ever, (Click the link in the upper right of the page) he has most parts for these old bike. I seem to recall that he has some covers listed in his catalog as well. But not sure. Honestly though that cover that you showed the picture of is not bad. Little cleaning and that looks like it would be good as new. But pictures are decieving. Good luck!
  3. bigfitz52
    That cover is FINE it simply needs to be refinished, I don't see any gouges or road rash.
    Strip with Aircraft Paint remover to get rid of the old clearcoat (the corrosion is UNDER it;)
    Sand, beginning with about 800-wet, then 1200 then 2000;
    then polish it.
    You can get new "YICS" plates from XJ4Ever if you're so inclined.
  4. smileyseca
    Colorado
    This one specifically has a couple dents down at the bottom and a dent or puncture about 3/4" above the M. It's not in bad shape, I agree. But I would like to get two matching ones. I don't want one to be smooth and the other to have the YICS on it. I'm looking through XJ4Ever, I feel dumb for not looking sooner. Thanks for the tips and help guys, this is definitely why I come here.
  5. bigfitz52
    Ahh, gotcha. I see the little hole now.
    Just don't be turned off by the grey "mottling" alone on used/eBay parts; that can easily be defeated, and minor road rash can be sanded out.
  6. MiGhost
    MiGhost Well-Known Member
    Still showing as available in new, unused condition from Yamaha.
    4U8-15416-01-00 COVER, OIL PUMP $64.58
    4U8-15426-01-00 COVER, OIL PUMP R $69.30
    Ghost
  7. smileyseca
    Colorado
    MiGhost, it didn't link.
    But having the part number helped, I was able to google it and find it on several sites.
    THANKS!!
  8. pickardracing
    pickardracing Member
    Two Rivers, WI
    I've got the covers on my bike that I'm switching out for some X covers. I'd give you a steal on them, and they're in much nicer shape than those. PM me for info.
  9. smileyseca
    Colorado
    On Front Brake Calipers....what will fit?
    ONLY calipers from a matching 1982 XJ650r Seca?
    or will a caliper from a '82 Seca Turbo or Maxim or 650 L work? all three are on ebay and I need a front right one to replace the scrapped one I have.
    I think i remember reading the Turbo won't work as they used a different caliper and the Maxim one because the mounting bolts don't line up. Or am I wrong?
    thanks!
  10. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Parts fitch http://www.yamahapartshouse.net/oemparts/c/yamaha/parts
    You can look up your bike and find the part number then you can search the part number and see what bikes used it.
    Assemblies where 4K0-25810-02-00 is used
    1981 XV920RH - Front Brake Caliper
    1982 XJ650RJ - Front Brake Caliper
    1982 XV920RJ - Front Brake Caliper
    Disclaimer: check my work before you buy something.
  11. chacal
    Maverick has the correct answer.
    BTW, we have brand new calipers for your model bike available if you strike out everywhere else......
  12. smileyseca
    Colorado
    Thanks! I got ahold of one with the same part numbers as the XV920RJ. the front end of my bike is almost complete!
