passenger grab bar
Discussion in 'XJ Modifications' started by mgram, Oct 22, 2009.
  1. mgram
    mgram New Member
    I have an 82 maxim 650 and i have been wondering if i can take off the grab bar? to me it looks as if it helps support the rear struts but i dont really know. So has anybody taken the rear grab bar off an 82 maxim650 and all is still good?
  2. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    I have an 81 xj650, they are basicly the same setup I believe. You can remove it, but you will need to add washers/space to cap nut for shocks to take up the space left from the grab bar. Also, you will loose the seat lock assembly. Hope this helps with your decision.
    Gregg
  3. mgram
    mgram New Member
    Yea, that helps. Thanks dude. I plan on ditching the stock seat when th rail goes. Thanks again
