Performance ignition?
Discussion in 'XJ Modifications' started by Bane, Sep 30, 2008.
  1. Bane
    Bane Member
    Fargo, ND
    So, I decided to ugrade my coils and wires. My question is, Is there an ignition ugrade for an 82 Maxim 650? Something better than stock or is stock the the top of the mountain?
  2. coachholland
    coachholland Member
    Georgetown, KY
    That's a good question and i'm interested in this as well... does Accel or MSD make a compatible product for us?
  3. YankeeSamurai
    YankeeSamurai Member
    you could get the same benifit by installing a hotter range plugs and removing the resistor from the ends of the plug wire...
  4. coachholland
    coachholland Member
    Georgetown, KY
    Hotter and cooler plugs don't refer to the amount of spark, the temp range refers to the properties of the plug in regards to heat dissipation from the cylinders (at least that is the impression I am under). From what I've read on these bikes, going a range hotter on plugs would be a bad idea. Stronger spark doesn't always mean more heat. Only going by what i've been told though, so I have no clue and could be talking out of my butt here.
    On my Durango I went with a range cooler plug and a MSD ignition to avoid the dreaded "death flash" software update for the PCM from the dealer which retards the timing and kills performance and MPG and it worked great.
  5. SQLGuy
    SQLGuy Well-Known Member
    You're right about the plugs: heat range has to do with keeping the plug at the correct temperature to self-clean and not glaze. It does not have anything to do with spark strength (other than a too cold plug fouling easily).
    Chacal has some aftermarket, higher voltage, Dyna coils that are a relatively easy fit on XJ's: http://xjbikes.com/Forums/viewtopic/t=7 ... plugs.html
    On my bike I retrofitted a pair of GM Saturn coils, but I am also driving them with Microsquirt rather than from the TCI module. I am not sure how well or even IF the TCI module would drive them.
    I used Accel 7mm silicone non-resistive copper core wire (special order from local auto parts store), NGK resistor caps (local Yamaha dealer), and Belden silicone boots (NAPA).
  6. TheHound
    TheHound Active Member
    Scotia, NY
    Not to hijack the thread but, if you are not using the TCI were do you get your timing from?
    Maybe I just don't know what microsquirt is.
  7. wizard
    go platinum plugs, ask congress for funding.
  8. flash1259
    flash1259 Member
    W.R. Wisconsin
  9. chacal
    Why not, everyone else is!
    You're funny, even if it is so g-d sad..........
  10. Robert
    Coach, both Dyna and Accel market replacement coils for your machine. I own both but have not installed the Dyna coils to date. My Accel coils were nice but required making a mounting bracket.
  11. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    As far as Platinum plugs, I'd avoid them in these old bikes. I've been told by the Bosch Rep that (and I can't quite remember why) Platinum plugs in an
    older ignition system will actually make the vehicle harder on fuel and not run as well.
  12. SQLGuy
    The whole story's here: http://residentialcolorado.com/SECA_750i.htm
    Well, at least, that's most of the story. My bike was damaged when a guy ran it over in a parking lot a couple of months ago. It's repaired now, with a number of aftermarket parts, and I am in the process of changing a couple of things at the same time (new fuel rail, retune for MAC exhaust, and such). I'll update the web site when that's done (hopefully this weekend).
    Paul
