Petcock problem?
Discussion in 'XJ Technical Chat' started by Lokitruck, Jul 31, 2015.
  1. Lokitruck
    Lokitruck Member
    Bealeton,va
    i took my petcock off my tank to have the tank painted. While i have been having issues trying to get gas flowing i decided to blow on the nipples of the petcock to see if air blows thru. Air flows nicely thru the big nipple but when i blow on the small nipple no air flow at all. Is this right? I recently rebuilt the petcock im just wondering if i should do it again
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Small nipple is for a vacuum source. When vacuum is present (engine running) it pulls open the internal fuel valve. This allows fuel to flow from tank to carbs.
    If you were able to blow through the small barb, then the rubber diaphram is compromised. That would allow fuel to be sucked in by vacuum and not through the carbs.
  3. Lokitruck
    Lokitruck Member
    Bealeton,va
    Ok. Cool rhank you
  5. hogfiddles
    And if you suck lightly on the small nipple ( there ya go, Matti), you can "feel" the diaphragm/spring do it's thing. BUT if you do it too hard, you can rupture the diaphragm, too, so be careful. If air keeps drawing through like sucking on a straw, the diaphragm is already compromised.
    Luis likes this.
  6. XJ550H
    just don't bite the petcocks small nipple to hard while you suck on it you may get slapped
    Luis and ecologito like this.
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Dammit am I that predictable?
    But you're correct... I was thinking it as soon as Loki started "blowing on nipples."
    Stumplifter and Luis like this.
  8. Lokitruck
    Lokitruck Member
    Bealeton,va
    Lol. I knew i was setting myself up for something but i needed the answer
  9. Luis
    Luis Member
    Seacoast NH
    gotta chime in..... This whole thread cracked me up:D... LAMO!!
    ecologito likes this.
  10. hogfiddles
    LAMO?
    ROTFLMAO!!!
    Too much bacon-flavored whiskey
    Stumplifter likes this.
  11. Takencareofbusiness
    Takencareofbusiness Member
    North Vancouver BC
    Too much Bacon-flavored Whiskey?..
    That's like having too many bikes......
  12. k-moe
    In Soviet Russia ALMO!
  13. MattiThundrrr
    With thick Russian accent: "In my country, ass laughs you off!"
    Yakof Smirnof
    never said this
  14. Luis
    Luis Member
    Seacoast NH
    Thick Russian accent:), as in Helena in BBC' Orphan Black....
    Too much bacon-flavored whiskey:D:D
    One too many 3 finger Balvenie:);):confused:
