petcock replacement
Discussion in 'XJ Technical Chat' started by feetballhabob, Apr 18, 2010.
  1. feetballhabob
    feetballhabob Member
    Kentucky
    I want to replace my pet cock on my xj700x maxim I want a standard petcock cheap as possible?
  2. cutlass79500
    lawrenceville georgia
    are you looking for vac operated or manual .i just got rid of the vac operated one on my virago and replaced it with a manual on off reserve petcock bought it from yamaha . found the number on another forum for it .i want to replace the one on my x also its working but i dont like the idea of when the petcock starts to go bad of taking a chance of flooding the cyl and hydrolocking and bending a rod . bolt spacing is 34mm on the virago if your interested i will measure the bolt spacing on the x make sure its the same. it costl $19.98 thru yamaha let me know
  3. chacal
    the 700's and 900's use a 44mm petcock (bolt spacing)...........
  4. cutlass79500
    chacal if anyone would know it would be you have you seen or have any manual petcocks in 44 mm if not. i will research it see what i can come up with. im off work for 3 months (medical condition) and have lots of time to research thanks
    just found the article on here and saw some online . only wish they were as cheap as the 1 for my virago
  5. feetballhabob
    Kentucky
    hey cutlass where did you find the article
  6. cutlass79500
  7. feetballhabob
    Kentucky
    does any one have a make model and year of a bike who's non vacuum petcock will fit an 85 xj700x. My local Yamaha dealwer was no help would no even try to guess told me to go to a bike junk yard.
  8. wizard
    why don't you turn it into a manual tap by blocking the centre hole with epoxy putty?
  9. feetballhabob
    Kentucky
    how do my friend
    I would still like to have my reserve setting also
