Petcock Squirting Gas
Discussion in 'XJ Technical Chat' started by kq6up, Nov 27, 2008.
  1. kq6up
    kq6up New Member
    My petcock is squirting gas (no pun intended) when I rev it. Is there an "O" ring or gasket or something that needs to be replaced. I tried tightening the screws. This did not help.
    Thanks,
    Chris KQ6UP
  2. chacal
    Hey Chris......never a good thing. Drop me a PM and let me know what kind of bike you have; I have all the rebuild parts or complete replacement petcocks, on-off valves, filters, fuel lines, etc. available for these bikes.
  3. kq6up
    kq6up New Member
    I pulled it apart, and it looked like the gas was leaking past the diaphragm/gasket out through the orifice (this orifice allows atmospheric pressure in to push against the diaphragm causing the valve to open). It looks like it sucked the rubber into the groove of the orifice. I rotated the diaphragm 90 degrees since it still looked like it was in good shape, and put the petcock back together. Viola! -- it worked. It is also doing its job not allowing gas to flow. :D
    Thanks,
    Chris KQ6UP
  4. Palmer650
    Palmer650 Member
    Middletown, MD
    Wow, I should pull mine apart too and check it since i think the same thing might have happened. I was a little hesitant to dismantle it but it sounds pretty easy! Thanks kq.
    Where are you from btw?
  5. kq6up
    kq6up New Member
    I am from Grand Terrace, CA.
  6. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Pet(edited)???? Think maybe they have the old electronic snoop software screwed down a little too tight?
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Ehhhh, could be.
