Petcock vacuum line
Discussion in 'XJ Technical Chat' started by Plug, Aug 14, 2017.
  1. Plug
    Plug Active Member
    Missouri
    Quick question for you gentlemen, 750 Seca, does the vacuum line connect to carb 2 or carb 3? It was attached to # 3........but on the 550 it was on #2...... Which is the proper on for the 750?
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    It will receive vacuum no matter which carb boot it's hooked to, I usually hook them to the carb that the throttle cable hooks to, which I believe is carb #3. Not sure if that's 100% correct but has worked just fine for me.
  3. XJ550H
  4. Toomanybikes
    Tsawwassen bc
    Yea but parts are cheaper at
    yamahapartsnation.com
  5. XJ550H
    I just use it for the pictures and cross fit.
  6. Plug
    Plug Active Member
    Missouri
    Yes Sir, I do have the fuel line holder still on carb hat 1.
