PICK UP COILS
Discussion in 'XJ Technical Chat' started by RATTLECANREBEL, Apr 1, 2014.
  1. RATTLECANREBEL
    RATTLECANREBEL Member
    Brandon FL.
    OK I'm sure this is a dead horse around here but I'm still green to this site
    so first off the bike was running and sounded good but #4 was not getting hot on the pipe the next day bike turns over and won't start
    Battery reads 12.6 volts right now
    readings for the coils fluctuated like crazy in the high 17000's so got another set with warrenty and saw vid of the bike they came off running
    still not starting
    Now I've checked the pick up coils
    You can see in the pic's what my readings are on the meter and how it's set
    ARE THESE NUMBERS GOOD FOR THIS BIKES PICK UP COILS?
    AND ANYTHING ELSE I SHOULD CHECK? I'M SCRATCHING MY HEAD AT THIS POINT
    [​IMG][/url][/img][​IMG][/url][/img][​IMG][/url][/img]
  2. Polock
    idono, what's it say in your book.
    i'll let somebody else tell ya about filling in your signature
  3. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Sent a pm about the signature.
  4. chacal
    XJ650 models:
    Pick-up coils:
    1980-81 XJ650 Maxim and Midnight Maxim: 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982 XJ650RJ Seca (non-yics engines): 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982 XJ650RJC Seca (yics engine): 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982-83 XJ650 Turbo: 120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  5. RATTLECANREBEL
    Brandon FL.
    Thank you so much Chacal so based on yr info my system checks out to be functional and I have brand new resister caps and the battery is new as well as all the safety switches check out
    so I guess this means my CDI OR TSI BOX gave out huh?
    Robert
    P.S the bike is a 1982 maxim 650
    Thank you again
  6. RATTLECANREBEL
    Brandon FL.
    Oh Polock
    I bought this bike for $200 more than I figured it was worth with the Ideal of making it road worthy and doing a café/street tracker style set up on it painting it and selling it for a small profit as making choppers n bobbers out of unloved and badly treated older jap bikes has been my hobby sense I became disabled but this one just struck me as a good café or tracker candidate
    So I don't have a manual for this model friend
    Robert
  7. mlew
    mlew Well-Known Member
    Apex, NC
    Before you condem the TCI be sure the ignition cut off circuit is working. I think its the black/white stripe wire on the TCI connector. That wire should NOT be grounded. I had a bike one time that had that wire grounded in the wiring loom and it drove me nuts finding it.
  8. RPHRIDER
    RPHRIDER Member
    Huntersville, nc
  9. adrian1
    adrian1 Active Member
    Number 4 cylinder being cold, can you confirm the float level is correct? How old is that battery by the way?
