pickup coil
Discussion in 'XJ Technical Chat' started by wkxj, Mar 20, 2016.
  1. wkxj
    wkxj Member
    nm
    Hey guys,
    I just joined the forum yesterday and was very pleased to find it.
    Would someone know if 82 xj650 pickup coils will fit a 81 maxim 550
    Thanks Will
    as a full unit here are your chocies
    i will add this
    • so if the individual unit is the same size and will screw onto the plate it MAY work it has the same specs as a 550
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    wkxj likes this.
  3. XJ550H
    are both of your pick ups bad or just 1
  4. wkxj
    wkxj Member
    nm
    I'm not sure I tested them right. I tested from the wires going into the CDI and with the tester set to OHMs
    They read around 96 and 98
    Oh yea! I forgot to mention I'm not getting juice to the spark plugs
    The pickup coils had a lot of corrosion and I tried cleaning them up a bit
  5. XJ550H
    test from left connector of the TCI disconnect it you should have 650 ohms
    test the gray wire to the black wire and the orange wire to the same black wire
    NOT the black white wire.
    are you getting 12 volts to the tci?
    your specs
    XJ550 models:
    Pick-up coils:
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    to test coils
    disconnect the right side connector at the TCI redwhite wire to gray then redwhite wire to orange 2.5 ohms is what you want if out of spec remove gas tank and disconnect coils connector and read there. clean all connectors as you unplug them use dielectric grease when reconnecting them
    spark plug wires
    spark plug caps unscrew take them off and ohm them out 10 K ohms
    test wires 1 and 4 for 11K ohms
    test 2 and 3 for 11K ohms
    you will want to trim back the ends of the plug wires about 1/2 inch to get at fresh wire
    wkxj likes this.
  6. XJ550H
    wkxj likes this.
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    "I cant seem to post in the topic I started this morning.
    How is the best way to test plug wires being that the coil side is sealed?"
    Thanks Will
    Unscrew the ht caps from the ends of the coil wires.
    GaryH.
  8. k-moe
  9. k-moe
    Same as with any other coil. Primary side across the primary leads. Secondary side across the plug wires (be sure to remove the plug caps and measure those seperately).
  10. wkxj
    wkxj Member
    nm
    Thank You, I'll do some more checking.
    Thanks! Hows a good way to test the plug wires being that the coil end of the wire is sealed?
    I thik I'm missing something.
    The coils check out its the plug wire I need to check Are you saying the gray wire to the plug wire?
  11. k-moe
    No. Grey (or orange) to black. Plug wire to plug wire.
  12. wkxj
    wkxj Member
    nm
    so the end of #1 to the end of #4 and etc.
  13. k-moe
    Yes.
    Remember to remove the plug caps (lefty loosey) and measure the resistors in the caps seperately.
  14. wkxj
    wkxj Member
    nm
    will do
  15. wkxj
    wkxj Member
    nm
    Okay, everything checks out from the pickup coils to the plug wires
    but I'm still not getting any juice through the spark plugs
  16. XJ550H
    so you ohmed out all the components including plug caps?
    have you trimed back the sparkplug wires 1/2 inch to get to fresh wire ?
    do you get 12 volts to the red white wire on the right TCI connector with key on?
    does your side stand relay under the seat click when you turn the key?
    unplug it and test for spark again.
    the test for spark is to take a spare spark plug hook it up and ground the end to the motor and look for spark.
  17. wkxj
    wkxj Member
    nm
    Thanks! I'll check those things out.
    Yea I've been testing the spark that way
  18. k-moe
    Again, to make sure we are all talking about the same parts. You checked both the pickup coils (found next to the crankshaft under the round cover on the left sode of the engine) and the ignition coils (found under the fuel tank along the frame backbone). Is that correct?
  19. wkxj
    wkxj Member
    nm
    Yea sir, Every thing checks out even the red/white wire going to the TCI. I was jumping the bike from another bike. I went and got a new battery today and when it's done charging I'll try again. I also got some new NGK plugs to see if I can get a spark
    BTW the starter relay is bad so I'm crossing it with a screwdriver. I don't think that should make a difference though
  20. k-moe
    Correct; the starter realy would not be related to the ignition issue.
  21. wkxj
    wkxj Member
    nm
    DSC02443.JPG DSC02444.JPG Motor spins good with new battery but still nothing to the plugs.
    When I first took the cover off the pickups had a lot of crud around them.
    BTW do get adjusted?
  22. XJ550H
    there is no adjustment to the timing it is electronic.
    that looks really bad not sure if the rust will cause problems.
    I have a pick up base I will send you for postage if you want it, I will look to see if I have an extra rotor too
  23. k-moe
    Non adjustable. The TCI takes care of ignition timing.
    The starter spins, so it's not safety citcuit related.....
    The ignition system checks out in terms of continuity and resistences...
    I think it may be time to ship one of us your TCI for testing on a running bike, unless someone else has an idea of what else to check.
    You are making sure to ground a plug on the head when you check for spark?
    You haven't tried starting it with any of the plug wires disconnected with no path to ground? (This is a bad thing to do. Each coil has to have a path to ground or the TCI can be damaged)
    jmilliken likes this.
  24. wkxj
    wkxj Member
    nm
    Yea I cleaned the ends and put on a new connector. You can hear it click.
    I tried both ways with the relay on and off
  25. k-moe
    You have double checked that the ignition fuse has continuity and both terminals for that fuse have continuity (the fuse clips oxidize and crack with age, leading to intermittant contact)?
  26. k-moe
    Nevermind my comment about the safety really (I edited it out). It interrupts the starter motor circuit.
  27. XJ550H
    I just tested a TCI for
    macksimman
    and will be mailing it back to him tomorrow . 34 degrees 50 mile ride loved it.
    I would be happy to test your TCI for you. Just click on my avatar and start a conversation with me I will give you my address.
    if you have me test it I will send you the parts I mentioned above, Will have to check for the rotor.
    you will want to start using some penetrating oil on those screws that hold the plate to motor as well as that allen bolt
    do not remove them untill you get the part(s) treat them every day
    rocs82650 likes this.
  28. wkxj
    wkxj Member
    nm
    I got a new ignition switch from ebay . It was supposed to be a K&N but was a Emgo.
    I also put in new line fuses. 20 amp for the main and 10 amp for the other 3
    The main is hot and when I turn the key to on the other 3 circuits are hot
    I think its hooked up correctly
  29. XJ550H
  30. wkxj
    wkxj Member
    nm
    Sounds great!
  31. XJ550H
    sounds correct so you installed something along this line for fuses. and tail light lights up? when key turned on
    my test clip
  32. wkxj
    wkxj Member
    nm
    I did the test with the neutral relay and I'll check the starter cutoff relay in the morning.
    I think I checked it but I'll make sure
  33. wkxj
    wkxj Member
    nm
    I did my fuses this way
  34. k-moe
    Unplug the sidestand switch.
  35. XJ550H
    never thought to do it that way but it does give you access to both sides of the fuse holder to test voltages.
  36. wkxj
    wkxj Member
    nm
    tried that and with a new connector both
  37. XJ550H
    have you ohmed out the tci right side connector to the primary coil connectors at the coils for continuity?
    red/white wire to both connector and gray and orange
  38. wkxj
    wkxj Member
    nm
    Yea they checked within tolerance. I'll double check that in the morning also
  39. XJ550H
    not what I mean but as long as a test from tci connector gave you primary coil specs your wiring harness from tci to coils is intact
  40. wkxj
    wkxj Member
    nm
    Now I know what you're saying. From one to the other to check for breaks. continuityo_O:D
    XJ550H likes this.
  41. Rooster53
    Unless the neutral switch is the reason the starter cutoff relay is not working. The ignition safety circuit is controlled by the side stand relay, which opens a set of normally closed contacts if in neutral OR the side stand is up. You must have either a working neutral switch OR a working side stand switch to enable the TCI.
    In a working system that will disable the ignition if not in neutral as the side stand switch contacts must close to energize the side stand relay and enable the TCI when not in neutral. The neutral switch is effectively wired in parallel with the side stand switch in reference to the side stand relay, so as stated above, you must have a working neutral switch OR a working side stand switch to enable the TCI.
    For troubleshooting purposes related to ignition and enabling the TCI, remove the side stand relay temporarily. This will defeat the ignition safety circuit to the TCI controlled by the side stand relay that applies a ground through a set of normally closed contacts at the B/W wire to disable the TCI.
  42. k-moe
    I could have sworn I typed side stand switch relay. Thanks for the catching the mistake.
  43. wkxj
    wkxj Member
    nm
    Thanks for the help.
    Okay did a continuity test from the TCI to the coils
    red .4 ohms
    gray .4 ohms
    orange .4 ohms
    other red .7 ohms
  44. wkxj
    wkxj Member
    nm
    Should we test the TCI if those numbers are okay
  45. XJ550H
    above numbers show you have connections that is good.
    the last part to rule out is the TCI
    just to recap
    all ignition and pickup coils tested to spec
    spark plug caps tested to spec
    0 ohms on spark plugs
    good continuity to ignition coils from tci connectors
    you have 12 volts at the TCI red/white wire with key on
    correct spark plugs NKG D8EA gap .024 to .028 inch
    no spark when plug is tested against motor for ground
    did you cut the spark plug wires back about 1/2 inch to expose fresh wire?
    unless the condition of the pickup coil base plate is the problem being rusted as i would not know if it has to have a good ground to motor to work.
    I will send you a clean plate and rotor with the return of the tci if you want it tested.
    I know this can be a leap of faith for someone to just send a part to an internet forum poster, but that is up to you.
    I will leave it as a standing offer.
  46. wkxj
    wkxj Member
    nm
    You've been a HUGE help and I trust you completely.
    And I appreciate it and will return the favor when I can.
    I took your advice and did all of the above right down to snipping the plug wire.
    I'll go over everything one more time tonight just to make sure
  47. XJ550H
    try testing the black gray and orange wires for the pickup coils (left tci connector) to ground to see if there is a short .
    the cable is held tight tot the frame in its routing
  48. wkxj
    wkxj Member
    nm
    I don't know if I did it right but I set the tester to ohms
    touched the red probe to the wire black probe to ground on the battery
    got 7.2 for each wire
  49. XJ550H
    you need to retest tci connector first do not touch probe tips when testing
    I just checked mine with 6 position connector disconnected from TCI you should have no readings to ground.
    did all 3 of them to confirm
    meter set to 200 ohms probe to battery ground black reads open no continuity
    gray same open no continuity
    orange same open no continuity
    no reading on meter.
    your wires may be pinched some place in the routing
    disconnect the the Black /white wire and the other bullet connector it is the neutral switch wire and remove the whole harness.
    you will want to remove the lower plastic fender ,unstrap the frame straps follow down under motor more frame/motor bands holding it up.
    you will also may have to remove the shifter cover to get at the neutral connector.
    foot peg has to be removed to remove the shifter cover the shifter lever can be a pain to get to nut (1/4 drive extention with a 3/8 to 1/4 adaptor works)
  50. wkxj
    wkxj Member
    nm
    Haha The TCI is headed your way.
    Thanks for the info. I will defiantly check it out.
