Pilot Screw O-rings?
Discussion in 'XJ Technical Chat' started by Joshua Olkowski, Sep 12, 2018.
  1. Joshua Olkowski
    Joshua Olkowski Member
    Los Angeles
    I'm rebuilding the carbs on my 81 Xj550 Seca and after pulling out the pilot screws I noticed that there was the screw itself, a spring, and a washer. I did not see any O-rings. Should there be one? I am also one washer short. How important is that washer?
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Yes you need o rings and washers on all if them. Len can help you out with the correct ones
  3. k-moe
    Joshua,
    We would appreciate it if you kept all of your questions in one thread. That makes it much easier to follow your progress and provide the best help possible.
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    The o ring can get stuck in the bore. I use a paper clip straighten out and bend a small hook on the end and fish out the o ring.
    Jetfixer, Simmy and Chitwood like this.
  5. hogfiddles
    I have a precision screwdriver that is very thin, and I bent the tip to a flattened J, and reach down in to push/roll the o-ring away from the wall, and then hook it and lift it right out.
    Dave
  6. Polock
    i use a lug wrench from a '62 dodge polara
    fiveofakind, chacal and Stumplifter like this.
  7. k-moe
    Police package?
    chacal likes this.
  8. XJ550H
    there are tiny orings you need to find and remove them . make a hook and use a bright light.
    the washer seals the oring with out it the spring will damage the o ring.
    www.xj4ever.com aka chacal sells them
