Please Help Random Ignition Loss
Discussion in 'XJ Technical Chat' started by CruzNCycles, Mar 23, 2015.
  1. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    83 xj750
    It was running fine i rode thru the rain and all of a sudden my ignition cuts out (lights all good just really weak or no spark) I've gone thru and re soldered every connection in the harness added extra ground to coil s
    Separated headlight ground from pack and put that to the frame
    Anyway it stops running randomly at speeds then won't turn over for a bit then turns on or shuts off then starts right up
    Only thing is sometimes she'll ride great all day then it'll act up randomly
  2. Skwerly
    Skwerly Member
    Yucaipa, CA
    Definitely sounds like a ground to me... I'd trace them real, real carefully.
  3. k-moe
    Rain.
    Wet.
    Cracked plug caps, cracked plug wires, or cracked coils (likely all three). Water causes the high side of the circuit to short to ground. The water that is trapped in the cracks can take a very long time to evaporate.
    Fire it up in the dark tonight. See if you have a lightshow.
    jmilliken, CruzNCycles and FtUp like this.
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    you beat me to it. I was going to say the same thing.
    FU
    CruzNCycles likes this.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Dang it! I missed the rain part. I was gonna say fuse box. I'm never gonna make it to "genius" at this rate!
  6. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    It cut off three houses down thenI did see a small discharge from my right coil pack looked like it came from the ground wire Just before it started
    (First time I noticed it hmmm )
    !!K-MOE!!
    So what your telling me is there's water in my coil packs? What should i do? Is this a fix or buy solution? And thanks so much i woulda never thought to try it in the dark Haha been attaching and re attaching wires for two weeks.
  7. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    This is the perfect time to upgrade to dyna coils or accel's... They are cheaper than nos, and junkyard specials arent going to help you out in the long term.
  8. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Also acts up more on an up slope than flat ground if that makes a difference.
  9. jmilliken
    Dillsburg, PA
    You got moisture in your coils.
  10. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    So buying new ones is my only option?
    I've been looking into the dynas for a while i guess now is the time to get it done. Thanks so much guys i really appreciate the help
    Jmilliken thanks for the responses
  11. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    The green dyna coils right?
  12. jmilliken
    Dillsburg, PA
    Yes sir
  13. k-moe
    If your budget can afford new coils then you should surely get them, but if you can't cover that cost right now your current coils can be repaired (so long as they test good aside from the cracking).
    Clean the coils with denatured alcohol and seal the cracks with epoxy or black RTV. If the wires are cracked you can splice in new wires, and wrap the remainder of the old wires with self-amalgamating tape. The total cost of the repair will be less than the cost of one new coil.
  14. Skwerly
    Skwerly Member
    Yucaipa, CA
    i wonder if the ole salt in a bag trick would work like it does with other electronics...
  15. Skwerly
    Skwerly Member
    Yucaipa, CA
    i mean rice... been a long day. :D
  16. k-moe
    It would, but is unnecessary. The coil body has to be clean for the epoxy or RTV to stick, and the alcohol will drive any residual water out. A fella could even use brake cleaner.
  17. hogfiddles
    Yeah the salt will work...... Until everything rusts and corrodes
    jmilliken likes this.
  18. hogfiddles
    This can also happen when the bottom of the tank fills up with enough water over time to finally reach the petcock.....it doesn't just stop you all the time. Rather, it can just be at the line where depending on curve, hill, surge, etc....just enough water can get sucked in to cause stumbling, short-term stalling, momentary spark loss, etc..... The water can get in through the key hole, or past a cap that doesn't seal well anymore. Been there, done that.
    Yes, as others said, it's more than likely that water got into a crack in one or both of the coils and THAT takes a long time to work it back out. Could also be water in the the tci, seen that enough....could be a wet headlight bucket, too.....
    I would also HIGHLY recommend draining the tank, refill with FRESH fuel and put a dose of seafoam or star-tron to remove any other water that may still be lurking in your fuel system.
  19. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Dyna coils installed Man it runs amazing
    Still the same issue
    I'm going to change the tdi see if that helps
  20. hogfiddles
    Loose fuses/weak clips in the fuse box
  21. MattiThundrrr
    Hey! I said "fuse box" six days ago! Mebbe I am uh jeenyus!
  22. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    New tdi fixed the issue guess there's something wrong on the underside of the chip
    Gonna pull it apart and re solder everything to have a back up working one thanks a bunch for all the help
  23. k-moe
    There is not any old bike that has only one thing that has to be fixed. One set of symptoms can have multiple causes, and sometimes it turns out that every damned potential cause is present on the machine.
