Please take a look at my valve clearance numbers...
Discussion in 'XJ Technical Chat' started by KumanK, Dec 2, 2011.
  1. KumanK
    KumanK Member
    Oceanside, Ca
    Intake
    1- .005/.127 Y290
    2- .005/.127 Y280
    3- .005/.127 Y290
    4- .004/.102 Y290
    Exhaust
    1- .004/.102 Y295
    2- .005/.127 Y295
    3- .005/.127 Y290
    4- .004/.102 Y285
    Please let me know what shims I need if any at all.
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Your new valve shims Sir...
    i1 no change
    i2 no change
    i3 no change
    i4 285
    e1 285
    e2 290
    e3 285
    e4 275
    Although intakes 1,2, and 3 don't need a shim now, they most likely will, so keep the pad numbers for reference the next time you check the valves.
  3. KumanK
    KumanK Member
    Oceanside, Ca
    Thank you very much... I really appreciate it. I just have to put an order in to chacal now. Anyoneknow what he charges for each shim?
  4. tskaz
    tskaz Active Member
    It's $7.50 per shim if I remember corectly
  5. KumanK
    KumanK Member
    Oceanside, Ca
    nice that wont break the bank
  6. wizard
    tskas, the first 3 inlet that are bang in the mid range, I would fit the next size shim down, while I was in there. just my 2c. Wiz.
  7. PGDBUD
    PGDBUD Member
    34.116992/-117.403765
    The price has gone up to $8.50 for the aftermarket shims...still a great deal.
  8. maverickbr77
    maverickbr77 Member
    Lowville, New York
  9. KumanK
    KumanK Member
    Oceanside, Ca
    from what I have read...they fit but they don't "really" fit. From my experience you don't cut corners with engine internals. Not saying you did, I haven't heard of them but reading up its a hit or miss.
  10. bigfitz52
    The Yamaha electrons will detect and possibly repell the Kawasaki electrons causing "shim rejection." And that's the last thing we want.
    Seriously though, it has to do with the chamfer (or lack of it) on the edges; I'd stick to Yamaha shims too.
    tskaz got your shims right.
    You'll want to think about replacing the valve cover gasket soon (depending on its condition) and when you do, be sure to replace those rubber/metal "donuts" on the bolts. You'll notice that the bolts have "stop" collars to prevent overtightening; the donuts are what actually press the cover down against the gasket/head.
  11. KumanK
    KumanK Member
    Oceanside, Ca
    nice I just have to get my order into Chacal, thanks for all the help everyone. @ Fitz, I have a new valve cover gasket coming but did not order the donuts, are they a must replace item?
  12. tskaz
    tskaz Active Member
    You should definitely replace those donuts when you replace the gasket. If they are the least bit worn (very likely) then your new gasket will do you no good...it will leak.
    The good thing about the rubber gaskets and donuts is that they can be re-used a few times when they are new.
  13. bigfitz52
    As above, YES. They do the work.
