"Plug Chop" - RPM or speed?
Discussion in 'XJ Technical Chat' started by baytonemus, Aug 6, 2012.
  1. baytonemus
    baytonemus Member
    Minnesota, USA
    I'm curious as to whether it's necessary to get the bike running at highway speed in order to do the traditional "plug chop" test. Will running at high RPM in a lower gear get the same result?
  2. bigfitz52
    Only sort of, because the load characteristics are different.
    Running at a higher RPM in a lower gear will give you better results than you'd get with NO load, however.
  3. TIMEtoRIDE
    If a person were to do "Plug Chops" for the purpose of adjusting the Pilot Jet, then the bike should be run under a load condition that is "off-idle", but not engaging the Main Jet or Slider-Needle.
    This would be about 2MM of "twist", maintained for about a minute, then kill and coast. I think 50 MPH in top gear would do it.
    Other throttle settings would test other parts of the carb.
  4. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Never heard of doing a plug chop for the pilot jet. That's not the common way to find the right setting for the pilot jet.
  5. TIMEtoRIDE
    But it's the only thing that's easily adjustable, and it affects drivability.
