Polishing Valive Cover
Discussion in 'XJ Technical Chat' started by kontiki, Jun 2, 2012.
  1. kontiki
    kontiki Member
    Columbia, SC
    So I'm finally gotten around to adjusting my valves on my old 1980 XJ650. Carbs are all clean and ready to be installed. :D
    I tried cleaning it up with 00 and 000 steel wool and barkeepers friend... its clean but still looks like crap. Whats the best way to polish these aluminum valve covers? I hate to put it back on looking like this after all the TLC I've put into this bike.
    Attached pic is what it looks like after my attempt at cleaning. After 30+ years she deserves to be brought back to her former glory, I'm cleaning up the rest of this bike. Any suggestions?
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    I think I still see 30-year-old clear coat lacquer on there. Strip that off first with aircraft remover.
    There are a few polishing threads here with good info. Some people get their aluminium parts as shiny as a mirror - someone even did it to they oil fill cap!
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    :D Where can I get "aircraft remover"? I got planes all over the place! 8O
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    What you gettin'' at, Bob? 8O 8O 8O
  5. kontiki
    kontiki Member
    Columbia, SC
    I think I'm gonna get a buffing wheel for my drill... and some also for my dremel which will probably help getting into the lettering and little crannys.
  6. Metal_Bob
    Bourbonnais, IL
    I thought I had OCD tendencies.
    I'm just jealous and not that patient!
  7. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    you can get aircraft stripper at most auto stores....
  8. Metal_Bob
    Bourbonnais, IL
    any paint dept. ie walmart, menards, autostores, farm & fleet stores, etc.
    Its a larger spray can any typically around $8 usd.
  9. tskaz
    tskaz Active Member
    Just don't get it anywhere you want to keep the paint.
    I use a bench buffer, much less work. Although i did use the dremel on the 710 cap and the spokes on the rims.
  10. Metal_Bob
    Bourbonnais, IL
    Another TIP I got on this forum - Permatex Gasket Remover in airesol can.
    I got one in a small can that came with a brush on tip instead of a normal spray nozzle.
    Its good at getting out really stuck on stuff on small crevices or where you don't want to SPRAY remover.
  11. kontiki
    kontiki Member
    Columbia, SC
    Thanks fellas.
  12. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    And I thought an aircraft stripper worked in the bar on a 747!!!!
  13. bigfitz52
  14. mtnbikecrazy55
    and try to stay away from steel wool, it can embed small steel particulate into the soft aluminum and when water gets on it, small little rust flecks can sometimes occur. just a word of advide :)
    happy buffing!!
  15. kontiki
    kontiki Member
    Columbia, SC
    Did some work this weekend using 800grit and some mothers and buffer wheels. I have a bit more work to do and then 1000 grit and final polish but I'll get it looking decent.
    Any ideas on the type of clear coat I should use on it?
  16. tskaz
    tskaz Active Member
    Some explanation may be in order here.
    Polishing is using wet sandpaper to smooth the surface of the part. A necessary step to achieve a pinhole free finish.
    Buffing is using a compound and wheel as your sanding medium to wet sand even finer, more microscopic holes in the surface of the part.
    You want to polish the part first, then buff. Use 800g, 1000g, 1500g, etc. moving in a different direction each time your switch grit so that you can tell when all the previous grit polish is out of the part.
    After polishing, then move on to buffing. Here is where all the wet sanding you did previously comes in to play. If you are using a bench buffer then you can pretty much stop at 800g sandpaper. If using a Dremel or drill, then you will want to move on to 1000g. If you are going to leave a satin finish, then go all the way to 2000g.
    If you want the mirror shine, like chrome, then buffing is in order.
    The valve cover is looking good, but if you are buffing in between grits then you are just wasting your time and materials.
  17. kontiki
    kontiki Member
    Columbia, SC
    I just discovered you are 100% correct. I had wet sanded most of the finish off with 800 then went to buffing with dremel (with some red compound) then went to mothers and brought up an almost chrome finish on parts of it.
    So just this evening I went back to wet sanding the remove the remaining finish and oxidation. Now all the buff shine is totally gone so I wasted my time doing that. But at least I know how good it will look with buffing and the Mothers.
    I think one more wet sand with 1000 grit all over will do it then finish up with buffing only.
    This is a lot of work. I've learned something though for the other covers. Thanks for the input.
    @Fitz: I looked at a can of that gasket remover at autozone but it was $10 for a tiny can. For what little finish there was left I figured it wasn't worth it so I substituted elbow grease.
  18. biggs500
    biggs500 Active Member
    Sherwood WI
  19. dmccoach
    dmccoach Member
    NE PA
    Rub, rub, rub and rub more -- try not to use paper too rough 1500 - 2000 stuff -- scratches just have to be then removed -- try a buff wheel it's tough to get into the right angle spots... or one of these with small buff wheels http://www.amazon.com/gp/product/B001PT ... 00_s00_i00
    This stuff works for me too (to finish up):
    http://www.amazon.com/gp/product/B004MN ... 04_s00_i00
    Some times it takes a few days -- work till you get "peeved" over it -- put it aside and do more the next day -- after several days it comes out well
  20. biggs500
    Sherwood WI
    +1 dmccoach!
  21. kontiki
    kontiki Member
    Columbia, SC
    Holy cow! Engine is looking sweet there dmcoach. That is the way I want mine to look.
  22. tskaz
    tskaz Active Member
    Which is why I love my bench buffer, cuts about 75% off the time it takes to do one part.
    kontiki, FYI, use a buff wheel with brown or white compound to remove the polish. Red rouge is just for shine, there is no cutting action. Same with Mother's, it's just used to remove slight oxidation, It doesn't smooth out the microscopic holes, which is what makes the mirrored shine.
  23. bigfitz52
    Yes, Aircraft Paint Remover is $10+ for a quart can. But that can goes a LONG WAY and sure saves a whole lot of elbow grease.
    After stripping, you can do it all with light wet sanding, an electric drill and some cheapo buffing wheels from Home Depot. This bike spent 4+ years straight outside (in Michigan, winter and all) before I got it and brought new meaning to the to the words "grey mottled corrosion." No bench buffer and a lot was done purely by hand:
    Wet sanded and electric drill/hand polished (different bike than above:)
    Those three lines are all that was left of some serious road rash; I didn't want to sand away any more metal. At least it's better than the crudely repaired cover it replaced, and I still haven't found a better "late" cover.
  24. jmilliken
    Dillsburg, PA
    Fitz... how about I just deliver my bike to you over the winter?
  25. fintip
    fintip Member
    Austin
    Man that's a pretty bike, Fitz. One of these days I'm going to have to get a seca...
  26. kontiki
    kontiki Member
    Columbia, SC
    Very sweet Fitz! There are other things on my xj650 I want to polish up also but I'm taking a top down approach. :^)
    After a lot of work my valve cover is nearly finished. I just need to give it a final buff out and then clear coat it with something. I am still deciding on what I want to spray it with... or even if I should spray it at all.
    I'll post a final pic of my cover here shortly.
  27. dmccoach
    dmccoach Member
    NE PA
    Clear coating will darken the alu and will only fade or chip in the future - just leave it naked and ocassionally polish/protect it with Mother's or similar for (IMHO) a better look
  28. kontiki
    kontiki Member
    Columbia, SC
    Roger that. Thanks.
  29. kontiki
    kontiki Member
    Columbia, SC
    Re: Polishing Valive Cover - finished
    Well, it took a lot of elbow grease and some dremel action. It would have been nice to have a professional buffing machine but alas... this will have to be as good as it gets for my purposes. This is a hard part to polish because all of the cracks and crevasses.
    I still need a 255 shim before I can button this thing up, if someone has one to trade I'll give 3 different other sizes in trade. :D
  30. NigeW
    NigeW Member
    Bradford, UK
    That looks really nice. As mentioned above, steer clear of applying lacquer (which won't stick to that shiny surface anyway) and just keep it buffed up now and again by hand. Use Solvol Autosol or similar with a soft duster.
  31. dmccoach
    dmccoach Member
    NE PA
    Nice job
