Popping on deceleration
Discussion in 'Hangout Lounge' started by tabaka45, Jun 24, 2016.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I read on a Honda forum that if the exhaust pops on deceleration it indicates that the bike is running lean. Anyone know why that would be?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Don't know why, but heard the same thing here.
    I had a popping on deceleration - then I rebuilt carbs (replaced 30 year old throttle shaft seals) and the popping went away.
    I used to have a 75 IH Scout (slant 4) with a cherry bomb muffler on it . . . You wanna talk about popping on deceleration? I would set off car alarms with it! The things that I thought were cool as an adolescent :oops: not so much now . . .
  3. k-moe
    Yes.
    I guess I should explain.
    First, a lean mixture burns hot. This results in hotter than normal exhaust gasses.
    When closing the throttle the engine vacuum increases, but the slide closes cutting off fuel from the main jet. The difference in pressure causes fuel to be pulled in from any available passage (the idle circuit (and en enrichment circuit if it's open/leaky)) as quickly as it can be drawn in. This results in a richer than normal mix.
    During valve overlap some of that rich mix is dumped into the exhaust.
    Remember what a lean mix does to exhaust temps?
    POP!!! Ignition of the rich mix inside of the too-hot exhaust.
    Stumplifter likes this.
  5. tabaka45
    Brunswick, Georgia
    Makes sense. I assume no damage to the engine but perhaps to the exhaust if too much.
  6. k-moe
    If you let a lean condition go on for too long you'll end up with a hole in the piston. Of course that depends on how lean it is.
  7. tabaka45
    Brunswick, Georgia
    My 2001 Honda 750 Shadow ACE with 37,000 miles is bone stock and it has always popped a little if I fully close the throttle. The carbs have never been touched so they still have the factory settings. I normally never fully close the throttle so it's not normally a problem. I wouldn't think the factory setting would be so lean so as to cause a problem--at least I hope not.
  8. k-moe
    OH. Ya, they do that. Honda set them lean to meet emissions, but safely lean (liquid cooled engines have greater safety factor). My son's ACE used to do that too. Now it only pops if you goose it a little before slamming the throttle shut. Be sure not to do that in the neighborhood at midnight; it'a very big pop ....lol
  9. tabaka45
    Brunswick, Georgia
    I'll keep that in mind for the 4th!
    jmilliken and k-moe like this.
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Does this condition sounlike a 'pop' like gunfire or popcorn, or a mild 'gurgle' when decelerating?
  11. k-moe
    It can be either. Depends on how lean and what the exahust system is.
  12. Stumplifter
    near Irma, WI
    When mine was doing it, it sounded like a rather cool gurgly pop, popping. :cool:
    Too bad it isn't an ideal tuned condition . . . .:confused:
  13. tabaka45
    Brunswick, Georgia
    I guess it is more of a gurgly popping. Certainly not a gun shop type. It only does it if I totally close the throttle. Sounds like an old car I used to have, so I'm ok with it--just wondering.
  14. k-moe
    The VT1100 ACE engine is really kind of a dirty-burner as engines go. So the stock tune is pretty much ideal for meeting emissions requirements and still having a strong-pulling engine.
