Possible Wiring Issue
Discussion in 'XJ Technical Chat' started by WesleyJN1975, Aug 23, 2010.
  1. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I noticed it when I was riding back home. When I reved the bike up, my turn signal would turn off. When at a red light in nuetral, if I rev the bike at all the green nuetral light turns off. Any idea where to start looking that both of these would be connected? Thanks as always for the help guys!
  2. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Bump!
    Any help is welcomed guys. Thanks.
  3. 1904xj
    1904xj Member
    San Diego CA
    Check for taped up wires that maybe gound off?
    Run trough your system sometimes the problem usaully sticks out like a sore thumb. People have a hard time beliving that an unproper splice can cause problems like this one.
  4. 1904xj
    1904xj Member
    San Diego CA
    I would start be checking all the wires in the front of the bike.
  5. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Thanks man. I'll start looking into it thursday after the rain stops, supposed to have a bunch of rain tomorrow.
  6. Danstona
    Danstona New Member
    Kitchener, Ontario
    Check your grounds...
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Anyone know where the ground points are located on my 650 Maxim? Thanks for any help you can give guys!
  8. Polock
    follow the - battery lead, between the engine and the swingarm, way down there
  9. KrS14
    KrS14 Active Member
    St Marys, Ontario
    You sit at stop lights in neutral? Tisk Tisk.. ;)
  10. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Well, it seems the problem was pretty simple. One of the fuse holders in the original fuse block came loose. I've so got to replace this fuse block with an updated one. Well, at least I'm riding again.
  11. wizard
    If the light has just turned red, knock it out of gear, for sure.
