Prepping and painting the frame
Discussion in 'Hangout Lounge' started by littlejohn, Jan 31, 2011.
  1. littlejohn
    littlejohn Member
    Barrow County, Georgia
    My frame needs to be sanded down and re-primed again. Since it was sitting outside in the weather (on the ground of all places) there is some surface rust that needs to be dealt with. I don't know anything about primers or paints and have to ask ...
    1. What kind of primer should I use?
    2. What kind of paint should I use?
    Also, I was thinking about painting it black, but I'm also considering silver. The bike was originally red. If I paint it black or silver, the frame will kind of disappear into the background but I think I want to make it pop a little. Any suggestions on a good contrasting color? Whatever color I use I'll also use for pinstriping or something on the gas tank so it all flows together. I do plan of keeping the original red color, maybe more of a candy apple though.
  2. bobberaha
    bobberaha Member
    Kentland IN
    Best thing to do is to have it sand blasted to remove all the rust then use a good quality primer sealer then use a frame paint eastwood makes good paints. Most body shops will sandblast bike frames fairly cheap.
  3. grinder
    grinder Member
    norfolk,uk
    i dont how the price differs over there to here,but a mate of mine sort of restores bikes as a kind of hobby.he usually has his frames sand blasted and powder coated.he reckons it costs between £100-£120.it would probably cost close to that for a sand blast and rattle cans to spray yourself over here.may be worth looking into having yours done over there?
  4. TIMEtoRIDE
    First, you need to get a primer that is compatible with your frame paint, or you risk an alligator skin looking reaction. They should be the same brand, or test the paint/primer.
    I painted my 750 frame "color-shift" and depending on the light angle, it goes from black to green to purple !
  5. littlejohn
    littlejohn Member
    Color shift sounds cool. I'm starting to lean toward yellow.
    I've got a sandblaster here at home. Shouldn't be too much of a job. I do have a powder coating gun too, but my oven is too small for a frame.
  6. dwcopple
    dwcopple Active Member
    bay city, michigan
    I've never had a bike that disliked Rustoleum from the quart can. Load the gun and spray away!
  7. Polock
    i used stripper on mine and every time i thought i had it all, i found a place i missed, then blasted any rust i found then
    painted with Rustoleum hammered finish, seems my regular Rustoleum
    takes days to dry ?
