Problems starting 82 Maxim XJ550J
Discussion in 'XJ Technical Chat' started by isaac728, Jul 26, 2019.
  1. isaac728
    isaac728 New Member
    Minneosta
    Recently I bought an 82 Maxim XJ550J, did a carb job and it was running fine until recently I went to start it and nothing happened. When I turn the killswitch from off to run the solenoid clicks but nothing happens when I push start. Any help would be appreciated.
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Try to jump it with a car battery and see if it starts. If so, you probably red a battery.
  3. k-moe
    The click you her when turning the ignition on is from the ignition cutoff relay (and that's a good thing).
  4. XJ550H
    do you hear the sidestand relay click too?
    if not remove the relay and see if it turns over
    another thing to check is the connector for the right control it is near the right ignition coil tight and clean
  5. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Neutral switch should be grounded and the side stand switch should be open(or unplugged). Could be solenoid, low battery or one of those safeties.
  6. isaac728
    isaac728 New Member
    Minneosta
    Update: all the relays were clicking and I removed the clutch and sidestand safety switches and tried starting, it didn’t. The only way I could get it started was to bump start it or jump the solenoid. I bought a new solenoid and it still doesn’t start. The battery is charged up just fine
  7. Ryengoth
    Wilmington, NC
    Is the neutral light on?
  8. isaac728
    isaac728 New Member
    Minneosta
    Yes
  9. Rooster53
    This is likely a terminology issue, but the starter solenoid should not click (it's really more of a clunck) when the kill switch is set to run. The starter solenoid when engaged supplies high current power to the starter just like when jumping across the two large nuts on the solenoid. If in neutral the side stand and starter cutoff relays should click when the kill switch is set to run, they make a very faint noise and it might be difficult to audibly differentiate as to which one is clicking or both.
    In order for the engine to turn over when the starter button is depressed you need a working starter safety circuit, start switch, starter, solenoid, and associated wiring. The side stand switch, side stand relay, and associated wiring has nothing to do with the starter safety circuit when in neutral, but is needed for the bike to run as it will disable the TCI if not functioning.
    One of the easiest questions to ask is if the oil light is illuminating when the starter button is depressed? If the starter switch is not working or is not properly grounded then the oil light will not illuminate and the starter will not engage. Common issues related to the starter switch is either a bad switch or improperly grounded right control / handlebars.
    A functioning system works as follows:
    Starter safety circuit = In neutral OR in gear with side stand up AND clutch pulled in
    Ignition cutoff = In neutral OR in gear with side stand up
  10. tabaka45
    Brunswick, Georgia
    You may also be losing voltage through the wiring system so that the starter is not getting enough voltage to turn the engine. (It is a very common problem with heavy equipment, and is solved by installing a starter relay that delivers voltage directly from the battery to the starter. Probably not practical on a motorcycle.). I would eliminate the battery by trying to jump it with a car battery, and then clean the starter switch and all wiring connectors, relays, switches, etc.
  11. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    Also, check your fuse's.
  12. XJ550H
    if you removed the sidestand switch you need to remove the sidestand relay it is under seat marked with blue.
    with clutch safety switch removed bike will only start in neutral this connector in bucket can be jumpered.
    when you press starter button does the oil light come on? if not starter switch needs to be cleaned or replaced, or your oil light bulb is burnt out.
    that relay would be called a solenoid;) on a motorcycle
