Progress with flashers
Discussion in 'XJ Technical Chat' started by JBL357, Mar 21, 2011.
  1. JBL357
    JBL357 New Member
    East Texas
    So re-looked over everything from fuses, relay, and to the switch and found that the solder on the switch had in fact came aloose on three wires. So re-soldered the wires and gave the turn signals a try. what i get is the left side lights up and stays lit solid no flash! and then when switched to the right side you just get a weird buzzing noise from the relay? ground maybe?
  2. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    Bad relay or your making a connection to ground would be my guess.... If the relay is "buzzing"
    Check the internals of the relay. sometimes you'll melt it inside and allow it to make a connection even though your wiring is solid
  3. JBL357
    JBL357 New Member
    East Texas
    well i definately shouldnt be making a connection to ground but i guess just about everything has been possible up to this point i will double check everything...
