Progressive Spring? Preload?
Discussion in 'XJ Technical Chat' started by myasylum, Jun 15, 2014.
  1. myasylum
    myasylum Member
    Grafton, WI
    Hi again!
    I bought a pair of Progressive Springs (11-1101) and I went to install them... I slid in the Spring and the included spacer and it sits exactly where the top cap would end. So it would have a "0" (or very little) preload. In a way... it fits perfectly under the cap... However I read there is suppose to be a 1" preload from what I have read. Should I be happy with it the way it is, or get a PVC piping that is 1" longer?
    Thanks!
  2. Polock
    i'am thinking i tried 1 inch and took it out and put a extra 1/2 inch in. total 1.5 inches. 15wt fork oil, same amount as original
  3. myasylum
    myasylum Member
    Grafton, WI
    The PCV tubing that came with the springs were 2". I went to Home Depot and added a inch. Now the spring and adapter go up to the top of the fork tube for a 3/4" to 1" preload.
    I guess we'll see how that works?!
  4. Kickaha
    New Zealand
    There isn't a set figure for preload, you preload them by what you need to get the correct sag figure
    http://racetech.com/articles/SuspensionAndSprings.htm
    Although it might not work with as well with progressive as they seem to be a one size fits all and all the top stuff is single rate
