Proper Way To Clean Windshild and Shild
Discussion in 'Hangout Lounge' started by happydog500, Mar 29, 2013.
  1. happydog500
    happydog500 Member
    Northwest
    My little windshield on the bike and the shield on my helmet is dirty. A friend told me he let a guy ride his bike and he came back and told him he cleaned the flip down shield on the helmet. He used the car windshield sponge at the gas station.
    Now, it's "wrecked" because he cleaned it that way.
    I never found how to do it without "wrecking it." I guess it puts scratches in it. How can I clean the windshield on the bike and my helmet without scratching it?
    Thank you,
    Chris.
  2. MiCarl
    Most glass cleaners have ammonia which will haze the Lexan used in shields and windshields.
    Mild soap and water is ok. There are specialty products, one is called Plexus. Plexus has gotten pricey and when my can is gone I might look for something else.
    I know National Cycle makes a cleaner, that I haven't used. I have used their Rain Zip to shed water and think that is awesome.
  3. FJRider
    FJRider New Member
    Alexandra, Otago, New Zealand
    Pledge spray on Furniture polish is what I use here in New Zealand. No doubt you will have a similar product there.
  4. RickCoMatic
    I use Palmolive Dish-washing Liquid to clean the Windscreen.
  5. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    i used the car headlight refurbish kit on a couple of peoples bikes. seemed to work for for them.
  6. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Common error with that type of plastic. Polycarbonate can scratch pretty easy and any abrasive, alcohol based, or ammonia based cleaner (windex) should be avoided. If it's in good shape the best thing is a very mild dish soap and lots of water with a terry cloth. If it's already scratched and hazy you can use a non-abrasive toothpaste with again lots of water (think wet sanding technique) and use side to side motions with a cotton cloth. Either way you don't want to apply a lot of pressure.
  7. FJRider
    FJRider New Member
    I found The Furniture polish returned my 20 year old FJ1200's screen to almost new looking. It seems to fill in the smaller scratches.
    Be gentle (and patient) and use a soft cloth.
  8. 750E-II_29Rbloke
    South Cheshire, UK
    I think Pledge has silicone in it (at least here in Blighty) so maybe that's what made the scratches appear less? I use furniture polish on my visor too, seems to do a good job of removing rubbish without damage and makes bugs (when we actually get bug weather!) seem to stick less.
    Also I use Bob Heath anti fogging spray on the inside during most of the year :cry:
  9. SteveM
    SteveM Member
    Ottawa, Ontario, CANADA
    I highly recommend Plexus plastic cleaner for your windshields and visors.
  10. hogfiddles
    My current fav. is PlastX by Maquires.
    dave
  11. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Windex makes an ammonia-free cleaner which works well for general cleaning. The headlight restorers and plastic restorers also work well, especially on fine scratches, just make sure to use a very soft cloth such as microfiber towels or cloth diapers (my rag of choice).
    You can also machine buff plastic if using a soft wheel and blue compound.
  12. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    My cleaner of choice is also pledge spray on. Also use the same stuff for the chrome and fibreglass parts. Just make sure your rag is soft and clean
  13. FJRider
    FJRider New Member
    I've found Pledge works well on visors ... especially in the rain. Water runs off easier.
  14. Mike82mxm
    Mike82mxm Member
    Ste,Annes,Manitoba,Canada
    Pledge uses wax in there products thats what making everything look new it fills in the sratches.Does a nice job but how much wax build up is there.It also helps with bugs
  15. FJRider
    FJRider New Member
    The first wipe with a damp cloth at a gas station to remove the accumulation of bugs, removes any possibility of build-up.
  16. gunnabuild1
    gunnabuild1 Member
    Soap and water and then the furniture polish for me,on a long run when you have a few bugs on the visor,couple of pieces of paper towel wet on the visor, then fill the bike up, wipe the visor down the polish seems to help the dirt and grime come off easily and when the bugs are damp they come off with a minimum of effort.
  17. Polock
    eagle one detailer, i find Pledge stays smeary unless you wipe it too much.
    eagle one, i use this on everything
  18. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Since the mosquitoes up here are big enough to actually RIDE your bike, we learn how to clean them up quick. I've always used dish soap and a microfiber (keep a spray bottle and cloth in the saddlebags), but I did decide to get some garage based specialty cleaners. Eagle One is on the list.
  19. raptor8
    raptor8 Member
    Bend OR
    SimpleGreen and water 50/50 in a squirt bottle and a micro fiber cloth. I used the simple green on my eyeglasses and the microfiber cloths are machine washable and available at Harbor Freight by the bag. Go Easy! Let it soak in and gently polish out, especially helmet shields!
    In winter, lemon juice or vinegar will keep your goggles or faceshields from fogging up.
    tips from a retired firefighter 8)
  20. cdnjj
    cdnjj Member
    Vancouver, BC
    Blue Wonder brand microfiber cloths work really well. I was skeptical that just a cloth with water could work but does. I use these things on everything glass or plastic I want clear and streak free.
    For polishing out minor scratches I have used Meguiars Plastx to great effect (works for hockey shields too). Go easy with it.
