Question about LED signals...
Discussion in 'XJ Modifications' started by MadCowInk, May 3, 2012.
  1. MadCowInk
    MadCowInk Member
    I have swapped out the dash on my '82 XJ750 with an acewell unit, and replaced the front turn signals with leds. With the bike in idle around 1000-1100rpm (with illuminated dash and running lights on), the voltage sits at approximately 12.8v, but when I use the turn signal, it drains the battery and the signals stop working around 12v. I have 25w6ohm resistors on the signals. There are no other constant drains on the battery besides the led dash, led running lights and headlight. Maybe the Idle rpm is set too low?Any Ideas on how to correct this would be greatly appreciated.
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Our bike's generators start working around 1800-2000 rpms (don't set idle that high).
    With the resistors your battery will drain.
  3. MadCowInk
    MadCowInk Member
    Need resistors to activate flasher... lower watt resistor perhaps?
    Or different flasher relay (don't need auto cancel).
  4. Davidkal
    Davidkal Member
    get an electronic blinker box at your local auto shop.....done
  5. Metal_Bob
    Bourbonnais, IL
    This one off eBay works great. Extra wire goes to ground. No autocancel though.
  6. MadCowInk
    MadCowInk Member
    Excuse my idiocy, does this mean if i get one of these new relay boxes I can ditch the resistors and lessen the load?
  7. Metal_Bob
    Bourbonnais, IL
    YES 8)
  8. MadCowInk
    MadCowInk Member
    Picked up a flasher on the way home today, worked perfectly! Didn't even remove the resistors and still no battery drain! Thanks guys.
  9. RickCoMatic
    Test:
    Charging System Output
    Measured at Battery.
    +14.2 ~ +14.5VDC @ 2000rpm's and above.
    Below +14.2VDC -or- Above +14.8VDC Require immediate troubleshooting.
    Inspect:
    Alternator Brushes and Alternator Rotor Face.
    • Brushes. 10mm Limit. 10mm -or- below = Replace Brushes.
    * Rotor. Clean Brushes Orbit Paths with Typewriter Eraser.
  10. MadCowInk
    MadCowInk Member
    will do Rick, thanks.
  11. strat
    strat Member
    Williamsport, PA
    would the LED flasher still be needed if you are running a set of led turns AND a set of regular bulb signals?
    the set I bought for the rear of my bike I can't seem to find in the standard bulb anymore. I found an LED set that look identical but i'm trying to figure out what I will need to do to make them work.
  12. superluckycat
    superluckycat Member
    United States of Insanity
    This does work like a charm. I was hesitant at first thinking there had to be more to it. Nope.
  13. Buffalony
    Buffalony Member
    Corning NY
    I havent really delve into the electronics pond with this xj650J yet, but I understand the electronics are pretty weak. I planned on replacing the fuse box. Would switching to LED be a good move as far as taking some load off the system? I think it would, but would like another opinion.
  14. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Leds are absolutely a great way to take some of the load off the system. Replacing the fuse box and cleaning up all of the connectors is also a good idea to get your electrical system working better.
  15. Buffalony
    Buffalony Member
    Corning NY
    Thanks for the reply. thats what I "ass"umed. Ill add LEDS to the list :))
  16. RickCoMatic
  17. Metal_Bob
    Bourbonnais, IL
    Keep in mind very few and no cheap led blinkers are DOT approved.
    Also many LED assemblies are not as bright/visible during the daytime.
    That being said pricey assemblies can be very bright. Those usually are $50+ each unlike $5 ebay bulbs.
    Another thing always buy color matched bulbs NOT white for use behind a color lens.
  18. sevesteen
    sevesteen Member
    Dayton, Ohio
    I tried a couple different LED turn signals when I wanted to put vintage aftermarket hard bags on my Seca. None were close to bright enough in daylignt. I got very lucky and found a second bike with both the factory luggage and the relocated turn signals to go with it.
