Question: Cylinder head leak XJ550
Discussion in 'XJ Technical Chat' started by mstubbs726, Oct 16, 2013.
  1. mstubbs726
    mstubbs726 New Member
    Boulder, CO
    Sooo, I was actin a fool the other day and decided that the head gasket was way over-torqued. I re-tightened the bolts to 16 pounds and tried to start my bike.
    Here's my issue:
    I forgot to tighten one of them, and oil comes drooling out from under the bolt, all over the place. Now, does anybody see anything wrong with tightening the bolt, replacing the lost oil, and trying to start it?
    I'm worried there would be oil in the cylinder now.
    Thanks,
    Mitch
  2. mstubbs726
    Boulder, CO
    For those that were interested,
    I followed the above procedure when the new battery came in and it rich for a moment, sooty black smoke, and then ran normally. No blue smoke, no oil. No leaks either.
    Now, onto that hard shifting...
  3. bigfitz52
    Let me guess: the bolt was one of the upper ones on the RH side.
    The reason oil came pouring out is because the washers on those bolts seal the oil galleries that feed the heads.
    Oil shouldn't have gotten into the cylinder as a result.
    But don't do that again.
  4. mstubbs726
    Boulder, CO
    Right you are Fitz! The feed for the exhaust cam right?
    Anyways do you have a good diagram of this engine? I'd really like to be able to visualize these internals better.
  5. bigfitz52
    Sure. The factory book has a "lubrication schematic" that's fascinating.
    PM me with your email address and I'll send you some scans.
