Quick question
Discussion in 'XJ Technical Chat' started by Coty, Jan 7, 2016.
  1. Coty
    Coty Member
    Frisco city, Alabama
    Since I pulled the mufflers off of my xj650 and put the tips on it idles ruff then will cut off at low rpm( under 1000). Is this a air fuel issue? It sounds like some popping in the left side exhaust. I'm going to make baffles for it soon to help with back pressure a little bit and to make it a little quieter.
    is it set to idle at 1k? should be about 1200 rpm check the inside of your sidecovers it will be listed there.
    could be an air fuel issue with no back pressure , you will have to blue tune and do plug chops to see if you are running rich or lean. change up the jets in the carbs if you are
  3. Coty
    Coty Member
    I wasn't sure what they were suppose to idle at. I just hear a pop in the right side exhaust. I'm going to make a set of baffles to quiet it down a little bit and may put in a lollipop baffle to give it some back pressure
  4. XJ550H
    Coty likes this.
  5. Coty
    Coty Member
    I couldn't download the link. Do you know how many turns it takes to set the air fuel screw?
  6. hogfiddles
    Mixture screws are set at 2.5 turns out from a soft-seat. Then fine-tuned from there.
    Dave
  7. Coty
    Coty Member
    I'm running straight pipes right now so I may have to go up a jet size. What size do I need to go to. I'm not running pods just straight pipe.
  8. hogfiddles
    The original mufflers are so free-blowing that if you are still using stock setup, just putting long noisy obnoxious sounding pipes on rather than the mufflers, you probably don't need to change jets
  9. Coty
    Coty Member
    Mine has 21" long exhaust chrome tips but they are just open. They don't have any muffler to them. I was wondering if I would have to change jets or not.
  10. k-moe
    Asked and answered. See Hogfiddles'post above yours.
    If you want to you can add temporary backpressure by stuffing coffee cans full of steel wool and wiring them over the ends of your pipes (imagine them being like a very loose fittting cap). That will give you a temporary muffler-like device.
  11. Coty
    Coty Member
    Didn't see hogfiddles reply until now. My computers acting a little weird lately.. I may try the lollipop trick. Have any of y'all tried it before.
  12. k-moe
    The only lolipop trick I know about involved a girl I used to date.
    Coty likes this.
  13. hogfiddles
    Very popular with the suzuki vl1500 crowd. That being said, I don't have the lollipops on my vl1500..... I have the Cobra straightshot exhaust, G-Man stage-3 carb re-structuring and jetting, K&N open air-filter, swirled baffles in the ends of the exhaust pipes.
    Is it loud? Yup
    Is it obnoxiously, annoyingly loud? Yup
    Do I completely contradict myself in saying that I have such a loud bike when I so staunchly am against loud bikes? Yup.
    It's for the times I want sheer brute power, for the days when I'm in a 'bad'
    mood, or the group rides where there are so many Harley-type bikes, that I just want to be loud too, rather than rev the mosquito-like engine. Though, most of the time I relish riding the 700 on those rides.
    Dichotomy, complexity, yup----
    Stumplifter likes this.
  14. Coty
    Coty Member
    I like that one k-moe! I seen something called a lollipop baffle awhile back. It involved an eye bolt and a big washer if u remember correctly. I think you turned the washer position and it tuned the exhaust sound.
  15. hogfiddles
    .... And there's that, too----- lol
  16. hogfiddles
    Yep, on the suzuki, the G-man company even calls them "G-pops"... And yep, that's basically what they look like
  17. Coty
    Coty Member
    Ok I knew I had heard about them. Just wasn't sure if they actually worked.
  18. hogfiddles
    I don't know how much they work...all I know is they are popular among the vl crowd
    Coty likes this.
  19. XJ550H
    i just did a download of it could be your browser
    Coty likes this.
  20. James r
    James r New Member
    Florida
    My xj 650 is very hard starting when its hot not sure why ?
  21. hogfiddles
    James, maybe you want to start your own thread so we can see what's up.
    Could be:
    - tight valves
    - clogged/dirty carbs
    - tci breakdown
    -gas cap vent issue
    -vacuum tube/fuel tube collapse
    -electrical issue
    -etc....
    So start a topic and let the the xj-collective brain get working on it----
    My first thought is probably carb-related......
    Dave
    XJ550H likes this.
