Radiator Delete 1986 XJ750 Maxim X
Discussion in 'XJ Modifications' started by Andrew Grierson, May 23, 2020.
  1. Franz
  2. Franz
    That's a 007 mod Mr Bond lol. Yes I thought if would be a brake lever just wanted to be sure.
  3. Polock
    just run the water through the frame
    jayrodoh likes this.
  4. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    I was looking over some older threads from before I got here. Read the OP's firts post up there and about fel out of my seat laughing ROF!!
    if his buddy said that... he is "NO" mechanic and should not be refered to as such.
    my favorite saying since i was a boy... "Everyone thinks their a mechanic...until they need one!"
  5. Franz
    Yes it would run hell of a hot without a radiator :eek:
    Mechanic1978 likes this.
  6. Mechanic1978
    NOYB
    if the bikes are known for running hot at stops, I bet it would be a gamble weather or not it boiled out on your leg, or pressurized enough to blow a hose out and spray you with boiling hot liquid, making the street and your footing all slick from the glycol.. wow what a mess that would be to see!
  7. Franz
    That must be the reason he wants the radiator removed ;).
  8. hogfiddles
    Many people will bypass the the temperature switch and wire in a toggle switch so the fan can be manually controlled
  9. Franz
    So is the standard setup a thermal switch in the radiator to operate the fan?
  10. hogfiddles
    Yep
  11. Mechanic1978
    NOYB
    @hogfiddles thats what I had to do to my cbr900rr, got motor built and that thing ran HOT! so I upgraded the rediator to a dual core 40mm polished aluminum and installed two 6" HV fans on a manual switch on upper fairing. much better...
