Re-Jetting carb/info needed
Discussion in 'XJ Technical Chat' started by Wagy, Mar 23, 2016.
Tags:
  1. Wagy
    Wagy Active Member
    PA
    I am in procces of reto mod on 85 700 maxim, I have the carb rack off and would like to see if anyone can tell me what size jets came stock in that bike and what size I might need after I install new shorty pipes ( keeping the 4 into 2 manifold ) and also replacing air box with 4 single pods. I would like to get the jets close while the carbs are off and resting on the work bench. Need size for the main and pilot jet, if anyone has a informed opinion.
    Thanks, Wagy
    Stumplifter likes this.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I have an opinion . . . not informed in the least bit.
    Don't put pods on.
    You will loose throttle response and what was once a great, smooth, fast, machine will have a bog to it and you will hate life and probably yell at your dog - misdirected anger after installing pods on an XJ is not a pretty thing.
    Sure pods look cool, but on these bikes they just shouldn't be.
  4. Wagy
    Wagy Active Member
    PA
    Hey Stump, I've heard that it can be trickey, but with re-jetting and determination, I think I can pull it off. Besides what good doing a resto and mod if you don't get it the way you want it, just my opinion, lol
  5. k-moe
    Everyone says that. Then they find out otherwise. CV carbs rely on smooth airflow in order to raise the slides and meter the fuel correctly. Monkey with that, and no manner of jetting will fix the problem.
    The only compromise (and it is just that, a compromise that smooths out the flat spots, but still robs the bike of power) is to use velocity stacks between the pods and the carbs. The airbox boots just happen to double as velocity stacks (it's almost as if a smart engineer played a role in developing the intake system).
    Unless you want to fit carbs with cable-operated slides it really is best to keep the intake system stock. However, if you really insist on fitting pods....
    If you're going to be getting fancy and modifying your intake or exhaust system, then you're going to be spending a lot of time re-tuning (re-jetting) your carbs in order to attempt to get them to run properly......and thus all the jetting size information from the above lists becomes somewhat useless (all the other specs will still be valid, though). Here's a few insights:
    WHAT ABOUT RE-JETTING FOR PODS, ETC?:
    It's a question we get asked often and unfortunately, one that we cannot answer honestly about your specific bike besides with "it depends".
    Which is a nice way of saying "you're about to enter the seventh circle of hell......."!
    Carb jet tuning required by aftermarket modifications is somewhat of a black art, part science, part skill, part luck. It depends on the current state of tune of your engine, your altitude, the mix of aftermarket parts on your bike, etc........a lot of variables.
    The best advice we can offer is: Just Say No. Don't do it! Leave everything stock!
    But, since most people---with good reason, I might add---don't always listen to our well-intentioned advice, then the next best recommendation we can offer is: "if you want more power get a bigger bike!".
    And since that doesn't cut it with many owners, either, for the remaining stalwarts out there who insist on "experimenting" with aftermarket intake and exhaust systems, here's the best information that we've come across to give you some GUIDANCE, which you should take as just that, and not as ANSWERS, because it isn't!
    MAIN FUEL JET SIZE CHANGES NEEDED PER TYPICAL MODIFICATION:
    Typical Exhaust Changes:
    +2 main fuel jet size for custom 4-into-2 exhaust
    or
    +4 main fuel jet sizes for 4-into-1 exhaust
    or
    +4 main jet sizes for no muffler (open headers)
    Typical Intake Changes:
    +2 main fuel jet sizes for single K&N filter (inside a stock airbox)
    or
    +2 main fuel jet size for drilling holes in the airbox with stock filter
    or
    +4 main fuel jet sizes for individual pod filters (no airbox)
    Additional changes:
    - Add up all the main fuel jet size increases and subtract 2 sizes.
    - Decrease main fuel jet size by 2 sizes per every 2000' above sea level.
    - Under a mis-match condition, such as when using pod filters with a 100% stock exhaust, or 4-into-1 header with stock filter and air box, then subtract 2 main fuel jet sizes.
    PILOT FUEL JET SIZES CHANGES NEEDED PER TYPICAL MODIFICATION:
    Pilot fuel jet size changes are related only to the change in main fuel jet sizes according to the main fuel jet size formula described above. Note that this pilot fuel jet rule is for the main fuel jet size change BEFORE any main fuel jet altitude compensation is factored in:
    Increase the pilot fuel jet size +1 for every +3 main fuel jet size increases.
    Additional changes:
    - Decrease pilot fuel jet size by 1 for every 6000' above sea level.
    PRECAUTIONS:
    - Make sure your carbs are in perfect working order before making ANY jet changes....meaning fully cleaned internally and rebuilt, operating properly in their stock configuration, proper sized air jets and needles, etc. Otherwise, you'll like find that all of your efforts are going to be a HUGE waste of time.
    - Check plug color often and adjust as needed, 2 main fuel jet sizes at a time and 1 pilot fuel jet size at a time. Bright white plug insulators are a sign of an overly lean fuel mixture condition and WILL cause damage to your engine over time, up to and including engine seizure!
    - Synch the carbs after each jet change.
    - Make sure the floats are set correctly
    - Seriously consider purchasing a Colortune Plug Tuning kit.
    - You may find it necessary to make changes to the size or shimming of the main jet needle. There are no guidelines on what or how to do these changes, this is true trial-and-error tuning!
    EXAMPLE:
    A 1982 XJ750RJ Seca using an aftermarket Supertrapp 4-into-1 exhaust and a single K&N air filter in the stock, unmodified airbox. Bike is primarily operated at an altitude of 2600 feet above sea level.
    XJ750 Seca Stock Hitachi HSC32 Carb Jetting:
    #120 Main Fuel Jet
    #40 Pilot Fuel Jet
    #50 Main Air Jet
    #225 Pilot Air Jet
    Y-13 Needle
    MAIN FUEL JET SIZE CALCULATIONS:
    Changes made:
    Exhaust:
    4 into 1 with Supertrapp = +4 Sizes Main Fuel Jet
    Intake:
    K&N Pod Filters = +4 sizes Main Fuel Jet
    Equals: +8 main fuel jet sizes above baseline
    Subtract: -2 main fuel jet size per formula above
    Equals: +6 main fuel jet sizes due to modifications, thus:
    Stock main fuel jet size is: #120
    + 6 additional sizes
    = a #126 main fuel jet size
    Subtract: -2 main fuel jet sizes for Altitude of 2500' Average
    = #126 calculated from above
    -2 jet sizes for altitude adjustment
    = a #124 main fuel jet size.
    PILOT FUEL JET SIZE CALCULATIONS:
    The formula is: +1 pilot jet size increase for every +3 main jet sizes increased.
    Stock pilot fuel jet size is: #40
    + 2 additional jet sizes (since we went up +6 main fuel jet sizes before the altitude compensation was factored in):
    = a #42 pilot fuel jet size.
    Note that no altitude compensation is needed on the pilot fuel jet since our elevation is less than 6000' a-s-l.
    RESULT:
    A #124 Main and #42 Pilot is A GOOD STARTING POINT.
    Note that the above calculations do NOT take into account any possible changes in the sizes of the main or pilot air jets, the main needle or main needle jet size, and thus are additional variables and opportunities for tuning excellence. These are areas which are largely unexplored by most tuners, but logically should allow for additional fine tuning or additional rage and frustration.........
    Normally, changing to an aftermarket exhaust does NOT require re-jetting, (or minimal re-jetting) as almost ALL of the airflow restriction in the airflow path thru the engine (meaning: ATMOSPHERE > AIRBOX > FILTER > AIRBOX BOOTS > CARBS > INTAKE MANIFOLDS > CYLINDER HEAD PASSAGES > EXHAUST SYSTEM > BACK OUT INTO THE ATMOSPHERE) is within the intake side of this air flow path, and primarily within the stock airbox/air filter. Your stock EXHAUST system can already flow more air volume than the stock INTAKE system allows.
    Thus changing only the stock EXHAUST system, with no changes to the intake side of the heads, normally makes NO DIFFERENCE IN TOTAL AIRFLOW, and "no difference in total airflow" means "no difference in TOTAL FUEL FLOW" either, and thus bigger jets are not needed.
    But once you start freeing up the INTAKE side of the entire system, you will produce more system airflow, even with a stock exhaust system (because, the stock exhaust system has the capability to flow more air through it than what the stock intake system allows).
    This is why re-jetting is usually needed even if you keep the stock airbox and the stock exhaust, but use a K&N low-restriction filter, or even if you drill holes in the stock airbox, or leave the filter lid off.
    All such actions free up the intake side airflow restrictions; the stock exhaust will move this additional airflow, and without providing addition FUEL flow to match the increased airflow (within limits, an engine will gobble up the maximum amount of airflow that it can; an internal combustion engine is actually just a self-powered AIR PUMP) then the engine will run "lean"---meaning not enough fuel to match the amount of airflow that the engine can (and now will) gulp.
    Most pod type filters allow for vastly increased airflow, and thus require fuel re-jetting, and although no one really talks much about it, probably also require AIR JET changes to match the additional fuel flow, but since no one likes to deal with two parameters at once, it becomes a "tuning nightmare".
    BUT, when you read all of the common symptoms of people who use pods, you quickly come to the conclusion that it's not possible to reproduce the stock "smooth in all rpm ranges" engine response. The reality is that you SHOULD be able to match it pretty darn closely, even with the increased airflow through the system, but ONLY changing the fuel jets isn't going to accomplish that. There are also air jets in the system, and they are there for a reason, as well as needle tapers and vacuum piston responsiveness issues.
    For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
    www.factorypro.com
    and then click on the "Product Support/Technical Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
    That's why we warn you that setting up a bike for pods can be quite a bit of trial-and-error procedure. You can make the calculations according to what is shown in that guideline and then order the jets that the "formula" recommends, and that should serve as a good STARTING POINT............you may (or may not!) have to do more tuning and trial-and-erroring substitution of different jet sizes, etc. to get it performing to you satisfaction, with the recognition that you may ALWAYS end up with a situation that has some kinds of trade-offs.....lazy at the lower end but runs well at mid/upper-ranges, or runs well at the lower end but a "flat-spot" at some other rpm range, etc. Unfortunately there is no magic formula........you might want to read through the factorypro.com article that I list at the end of that section, and you will get a better understanding of what is involved to get the carbs set-up properly in a non-stock configuration.
    As one of our favorite experts says about pod filters: "Get a Rubik's Cube instead.....it's less trouble and actually has an eventual solution!"
    Rav3n and Wagy like this.
  6. Wagy
    Wagy Active Member
    PA
    Thanks k-moe, u got me re thinking and a little bummed out. I really saw pods in my head and want to see them on my bike ! Not sure what to do now.
  7. k-moe
    There are a few members who have made a second sort of compromise; a shortened airbox with a custom fitted filter. There are just a few threads, so you'll have to do a search. Like I mentioned before, cable-slide carbs are an option, but you'll need to do some figuring and a lot of testing to get the jetting right (and you'll lose fuel efficiency and some throttle response there too).
    If you can live with the compromise then you can put on pods for the look. Personally I figure that anything that I can't see while I'm riding doesn't need to look cool.
    DrewUth likes this.
  8. Wagy
    Wagy Active Member
    PA
    Thanks k-moe. that long technical reply was what I needed to convince me of "NO PODS" Now I understand why it is more trouble than it's worth. Not only now, but permanaly into the future, and after all I do want to ride not tweek carbs all day, every day forever and ever. All good info guys, I will reconsider pods, with strong regrets. gonna sleep on it now. Thanks, Be back Soon. Wagy
  9. XJ550H
    get oversized ones and just wrap them around the airbox boots no one will know but you
    call them Faux pods, or sans pods
  10. k-moe
    Thank Chacal for the writeup. I just passed it along.
  11. hogfiddles
    Or a big pair of socks on......
  12. Wagy
    Wagy Active Member
    PA
    Funny you said about false pods, cause that was the idea me and my son came up with today.
    Either gonna drill big enough air tight holes and mount false pods coming out the side of the air box just seal off the inside of the pod, or maybe glue a pvc adapter to the side of air box and have it look like they are functional. But I'm not joining the " Pod club " and nobody is holding me or my parts for ransom !!!
  13. XJ550H
    it only looks like your parts are being held for ransom, it's actually your sanity that gets held:Blackalien
  14. Wagy
    Wagy Active Member
    PA
    Ya good luck with that XJ550H
