Ready to start after 1.5 years
Discussion in 'XJ Technical Chat' started by Onetrackstu, Feb 2, 2015.
  1. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    well it's finally ready to start running after 1.5 years of building except I do not know where to troubleshoot next. It has a custom harness, all shims at spec, 4-1 open exhaust, carbs are completely cleaned, rebuilt, and jetted (for pods and the exhaust combo), and I am not sure where to go from here to inspect and troubleshoot. Let me know your thoughts.
  2. chacal
    Well, it starts, so that's a ........ start.
    Sounds like the idle SPEED screw need to be turned up, sounds like it's dying because the throttles are almost completely closed. Does using a bit of choke help keep it running?
    Remember, the FIRST thing you're going to do (like within 60 seconds) of getting it running is to SYNCH the engine, that process gets rid of 90% of the rough idle/dying/hi-revving etc. issues.
  3. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Well I fiddled with the idle speed screw and even added a little starter fluid, but nothing. Yes I used the choke. I'm kinda stumped.
  4. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    it is not getting enough fuel
  5. k-moe
    Did you set the petcock to prime and wait for the float bowls to fill?
    Did you bench synch the carbs?
  6. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Yeah and its leaking fuel from where the fuel filter is located. I'm just going to take it out for now. The peacock is basically an on/off valve attached to a hanging "gas" can. I had the carbs professionally rebuilt and I'd put money on not being bench synched.
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Maybe the pilot screws need to be opened more. Are all the vacuum ports capped? Did you set the petcock at Prime to let the carbs fill. Maybe set it on Prime until you get it cranked and the vacuum opens the petcock.
  8. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Yes all the vacuum ports are capped. There is no tank on it so no petcock. I could probably open screws up and remove the filter. That way there is unimpeded flow.
  9. FtUp
    FtUp Well-Known Member
    pacific northwest
    it sure sounds like it wants to run. it just needs more air and fuel. I recommend double checking the float levels and making sure the pilot jet needles are 2.5 to 3 turns out. remember, float level is critical.
    FU
  10. Stormin
    Stormin Member
    Poughkeepsie, NY
    Can't wait to hear it running. Going to sound cool.
    Good luck getting it running.
  11. mwhite74
    mwhite74 Member
    Any luck?
    I'd turn the idle screw in even more and don't touch the throttle while you're using the choke. If the bowls are full and you have spark it should run.
    We won't get into the pod/open exhaust discussion, but that might be part of it too... Was it running pre-build? compression ok?
  12. Stormin
    Stormin Member
    Poughkeepsie, NY
    Did you get this running?
  13. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Na not yet. Antigravity battery ran out of juice, so I have to get a special charger for it...and I just got married so that comes with its own fun.
  14. Stormin
    Stormin Member
    Poughkeepsie, NY
    Congratulations on getting married.
  15. FtUp
    pacific northwest
    don't let it sit in a discharged state for too long, that is the quickest way to kill a battery.
    congratulations on getting married. I've been married for 8 years next month myself.
    FU
  16. Skwerly
    Skwerly Member
    Yucaipa, CA
    yea, almost sounds like those bowls aren't full.
  17. Stormin
    Stormin Member
    Poughkeepsie, NY
    That's what I thought,but I'm new at these xj's
