Rear brake shaft assembly XJ5500
Discussion in 'XJ Technical Chat' started by Jorge.Prelenzo, Nov 28, 2016.
  1. Jorge.Prelenzo
    Jorge.Prelenzo New Member
    Europe, Germany
    Hello guys, i am currently in the process of a dawn to frame restoration on my XJ550. The frame was sandblasted and powdercoated and the bike now looks as brand new.
    But i am facing some problems putting together the rear brake shaft assembly. There is a spring which just does not want to be assembled the way as is was before. (most probably i am doing it wrong)
    Can somebody shoot some pictuers and upload them for me? I would need the shaft assebembly, the foot brake lever and the sensor. TNX :)
  2. schmuckaholic
    California
    Not sure exactly which spring you're referring to, nor which shaft, but here's a writeup I did on replacing the rear brake shoes, from removal to reinstallation of the wheel, tension bar and coupler rod (with its spring).
    Replacing the rear drum brake pads
  3. k-moe
  4. XJ550H
    stand foot rest assembly
    part 4 connects to brake pedal
    I will see if I can photo this for you
    you also want a photo of the brake switch?
