Rear drum brake: Drum removal. xj650 '83
Discussion in 'XJ Technical Chat' started by cjweirzy, Mar 25, 2021.
  1. cjweirzy
    cjweirzy New Member
    Kelowna BC, Canada
    Redoing the brakes on the rear of my 83 xj 650. The drum has some serious wear and tear and I would think you should be able to remove the complete drum, but cant figure it out. Can anyone point me to some resources or let me know what to do or how to proceed?
  2. Simmy
    Easiest is to just replace the wheel.
    How close is your nearest bike breaker?
  3. k-moe
    The drum liner is a shrink-fit to the wheel. Replacement is not for the average home mechanic.
    While there are shops that will do that service, it's easier to get a replacement wheel.
    Link some pics of the drum liner just to let us be sure that you really do need a replacement.
  4. cjweirzy
    cjweirzy New Member
    Kelowna BC, Canada
  5. k-moe
    Ya. Chunks missing is bad. Don't use that wheel.
    Jetfixer likes this.
  6. Timbox
    Timbox Well-Known Member
    Wow, ya I am with k-moe, don't use that. If you did you never know if will hold up or just keep peeling bits off.
  7. cjweirzy
    cjweirzy New Member
    Kelowna BC, Canada
    Appreciate the advice! First time doing a bike. So far so good! There will be more questions in the future!
  8. k-moe
    Please keep them all in one thread so we can keep track of your progress, and not miss any issues that may come up.
    Also:Read This First
    cjweirzy likes this.
  9. Jetfixer
    Ebay usually has plenty of listing agree with Kmoe that is not a serviceable wheel , if it was just rust a wire wheel on a drill motor could clean it up, but thanks missing . Check Craig's list as well you might find a whole bike for sale .
  10. Toomanybikes
    Tsawwassen bc
    I have some wheels . I’m down near Vancouver (Tsawwassen)
  11. XJ550H
    if it is a 650 maxim consider a 750 maxim rear wheel the 750 has a wider brake shoe
  12. k-moe
    Which is an upgrade, but he needs be sure to get the brake plate and throwout arm along with the wheel.
    The Brake shoes are larger too, so he will need those as well.
  13. Toomanybikes
    Tsawwassen bc
    I probably have that as well, even an xj700 rear wheel and brake assembly
  14. Toomanybikes
    Tsawwassen bc
    This wheel is pretty good
