Rear gear oil cap?
Discussion in 'XJ Technical Chat' started by shepherd29, Sep 1, 2023.
  1. shepherd29
    shepherd29 New Member
    Indiana
    I recently got an xj650 for only 200 dollars. It still needs a lot of work, but I got it running again. I'm trying to replace all broken or Jimmy rigged parts with oem or oem equipment parts.
    What I need right now is a cap for the gear oil on the rear axle as the previous owner simply glued a vacuum cap on it and used a self tapper as the "cap"
    Does anyone know the part number or where I could get a replacement cap for the rear gear oil fill port?
  2. Dan Gardner
    Minneapolis, MN
    The fill plug sort of in the middle or the vent thing on the top?
  3. Toomanybikes
    Tsawwassen bc
    I use yamahapartsnation.com to look up part numbers
  4. shepherd29
    Indiana
    Having done a tad more research I now know it's the vent cap, not the fill cap
