Rear Shock Upgrade.
Discussion in 'XJ Modifications' started by stevermair, May 11, 2015.
  1. stevermair
    stevermair New Member
    Banff, Alberta
    Hey guys,
    Quick question, what is the safest, longest length I can upgrade my rear shocks to? I threw some 13 inch ones on to see how it looked and just rolling the bike a few feet, I could hear and feel some not so good sounds from the swingarm.
    Thanks.
  2. stevermair
    Banff, Alberta
    Sorry the bike is a 1980 xj650 maxim, thanks!
  3. XJ550H
    its probaly changing the angle too much for the shaft drive.
  4. Toomanybikes
    Tsawwassen bc
    Why longer most want shorter
    Or is it a sag problem stock length with a heavier spring is what I did 195 and passenger , Progressive with the heavy spring is perfect for 2 up riding
  5. Ribo
    Ribo Prefectionist
    I used 12-series progressives from chacal with performance springs. They were about the same length but much better than the stock ones. They're firmer at the top end but also have recoil dampening. I'm 210lbs and I ride them two notches away from top setting and crank them all the way for 2-up. Personally i think they're perfect.
    HCP9405 - body
    HCP9411 - spring
    These are the black ones you'll see in my showcase.
  6. Skwerly
    Skwerly Member
    Yucaipa, CA
    I have some real nice progressives on my jalopy, i can measure them out if you want.
