Rear shocks
Discussion in 'For Sale, Trade/Swap, Wanted' started by cdnjj, Sep 10, 2013.
  1. cdnjj
    cdnjj Member
    Vancouver, BC
  2. mindwebs
    mindwebs Member
    Elmwood, WI
    Possibly, the rubber ends can be swapped over from your old shock to get the correct bolt sizing, it doesn't list the lenth from eye to eye....
    That's where there might be an issue.
    I have 13 inch Harley air shocks on my Seca, but I also have a twitch I can't get rid of.
    Factory height is 12 inch.
    Adding height gives you more ground clearance and move leaning clearance, but it also changes the rake angle on the front end.
    I usually get the HD shocks for about $45.
    At $150 that's alot to risk that they might work.
    Pm me if you need more info on the HD shock set up.
  3. adrian1
    adrian1 Active Member
