rear tire off center, advise?
Discussion in 'XJ Technical Chat' started by Str Pimpin, Jul 18, 2016.
  1. Str Pimpin
    Str Pimpin New Member
    Fairfield, Ca
    Hello fellas plz i hope somebody knows an xj beeter than i do but i duno. I can hope cant i. I got an 81 xj 650 and a 750. The 650 has a fatter rear wheel so im thinkin switch em. I run accross a 3rd bike a 91maxim wt the entire rear swing arm , drive shaft and every musurment i can figure to take on the back wheel seems to me to be the same yet im kicked off center. Ive took it off and put it bach on several times and can find no reason its off center. Any suggestions fellas ?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Hi,
    Sounds funky!
    Is the drive collar exactly the same and/or is the spacer in the drive shaft different?
    All I can think of without checking parts diagrams.
  3. k-moe
    What's the third bike again? There was no 91 maxim.
  4. Str Pimpin
    Fairfield, Ca
    Im sorry. The third where the new wheel came from is a 91 valero or soething like that. And somethink is funky cuz its like the shaft dont wana go all the way threw. The treads barely come out the other side and the pinch bolt is hitting the exaust when i did clear it... it seems it needs to go in as far as the wheel needs to go over
  5. k-moe
    Could it have been from a Virago?
    Based on your description you aren't likely going to make that wheel fit without making spacers, or possibly machining the wheel.
    You might want to follow this, because I suspect that you have a Virago 535 wheel.
    Mr. Brown to the rescue!! The 535s have arrived!
    Jetfixer likes this.
  6. Str Pimpin
    Fairfield, Ca
    Yes your correct it is from a 91 virago but from everything ive seen the swing arm and drive shaft to the final drive and the wheel itself are identical even tho the rest of the bike is far differant from my 81 xj650 maxim
