Rear wheel gets stuck if put in first gear
Discussion in 'XJ Technical Chat' started by Jose Zambrana, Mar 2, 2020.
  1. Dave in Ireland
    Ireland
    Ow, that's a bummer.
  2. Jose Zambrana
    Jose Zambrana Member
    Miami
    Yes. That's what the manual says.
  3. Rooster53
    The third picture showing the large nut that secures the clutch basket it looks like the nut / basket is not fully seated; the nut should be flush with the end of the shaft. Perhaps you already started disassembly or it's just the photo?
    Was loctite used on the pressure plate screws?
    And what about the torque wrench? You typically need an inch pound wrench for numbers that low to get into the usable range of the wrench.
  4. Franz
    Has anyone used thread locker on clutch bolts? Just interested to hear your opinions on this.
  5. Jose Zambrana
    Miami
    I didn’t use loctite but will definitely use on the new ones that are comings. My torque wrench goes down to 5 lbs so I think its ok. Now, regarding the nut not being flush with the end of the shaft.... I didn’t notice that. I adjusted it to 52.7 lbs which is the specification. I will check that when I install the new one. Thank u for the observation.
  6. k-moe
    It's not OK. You want the target torque value to be somewhere in the midrange of the torque wrench's scale, or you won't get an accurate adjustment. This is more critical when the value is at the low end of the tool's range.
  7. Polock
    https://imgur.com/N6HXWp6
    i do know what happened to mine. put the bolts in finger tight, went for lunch, had a few beers, put the cover on and a few miles later.......
  8. Jose Zambrana
    Miami
    Did something else got damaged? I had to take out the oil pan to clean it from all the debris in there.
  9. Jose Zambrana
    Miami
    If someone knows, what it the reccomended measure of the 5 springs that holds the plate? I’ve look at the Haynes manual but I can’t find it.
  10. Simmy
    XJ650G
    clutch spring free length 40.1 mm
    minimum length 39.1 mm
    XJ650LJ
    clutch spring free length 42.8 mm
    minimum length 41.8 mm
    I just put Barnett's in my Turbo - 44.5 mm
    XJ900RK
    clutch spring free length 44.0 mm
    minimum length 43.0 mm
    I seem to have misplaced my XJ650RJC manual but I suspect same as 650G
  11. XJ550H
    upload_2020-3-19_17-5-21.png 650 seca specs
    Jose Zambrana likes this.
  12. Jose Zambrana
    Miami
    Thanks a lot to both of you! By tomorrow I should have receive all the parts as well as a new low torque wrench for those bolts on the springs. Hopefully by Saturday in the afternoon she’ll be running again. I really like this bike and don’t want to part ways with her. I want to get her running good.
  13. a100man
    a100man Well-Known Member
    Bedford, UK
    Damn, that's wretched luck..
    .. while your in there though how about a new clutch cover gasket? That orange gloopy
    sealant is no friend to oil-ways in any motor.
  14. Jose Zambrana
    Miami
    Lol. I already got the new gasket for all the side covers. Put the gasket maker on a hurry to get her running. She is running good now but I’m in the process of fine tuning the carbs. The rpm got very high when she gets warm. I adjusted the float levels and performed a bench synch and it change dramatically but still sometimes a bit high around 1,500-1600. New boots are in the way as well as an ultrasonic cleaning and completely new rebuilding kit. This next Saturday will be a busy one.
