Rear Wheel Question?
Discussion in 'XJ Technical Chat' started by Louie, Jul 9, 2007.
  1. Louie
    Louie New Member
    Colorado
    I'm in need of some help/suggestions,
    I have a 81' 550 maxim. Had some new tires put on. Went to reinstall the rear wheel...seamed easy enough, but something isn't right.
    I basically put it back the way it was, lines up the 'tick' marks on the frame w/ the chain tensioner so that both sides of the frame are on the same tick w/ respects to it's tightener. They are almost on the 4th tick counting from rear to front of the bike.
    When I turn the wheel, something is rubbing or misaligned. The wheel turns good about 1/2 way then seems to bind. The chain really isn't all that tight.
    I'm getting ready to take it off again. I plan on checking to see if the axel is bent by rolling it on a table. Could it be bad bearings? Any other suggestions for things to check?
  2. RickCoMatic
    What's is say on the tire ... for what tire size it is?
  3. Louie
    Louie New Member
    Colorado
    Dunlop 130/90-16 M/C 67H
