Rear wheel tire clearance
Discussion in 'XJ Technical Chat' started by joejr2, Aug 10, 2019.
  1. joejr2
    Santa Fe,NM
    Yesterday I installed the swingarm/drive shaft tube, final drive and rear wheel on
    an 82 650 maxim frame. the clearance between the tire ( 130/90-16 ) and the drive shaft tube
    was only 1/8." Is this normal ? Did I install the swing arm spindles incorrectly ? Is there a spacer
    ring around the rear wheel drive gear that I may have missed ? Is there a link to the proper
    installation procededure for those parts ? I have to pull all those parts off again anyway because
    I forgot to install the brake pivot shaft before the swing arm went in.
    The spacing you have is normal. It's a tight fit, but will be fine.
  3. joejr2
    Santa Fe,NM
    thanks
