rearsets
Discussion in 'XJ Modifications' started by ayudame, Sep 7, 2010.
  1. ayudame
    ayudame New Member
    new hampshire
    are there any that dont use the rear pegs? or will it be lots of fabrication?
  2. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    i took mine off. looks better and no problems. but i have smaller pipes that don't need the extra anchor point.
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    My rear pegs hold my luggage brackets on, but I just fold them up.
  4. poprider
    poprider Member
    Seattle, WA
    I don't use mine. You can take off the entire bracket if you have an exhaust that's only one side. But if you have two into two's, you can just remove the pegs themselves.
    But I will be putting in some better looking ones. I'm trying to get a two-person-seat-able cafe.
  5. ayudame
    ayudame New Member
    new hampshire
    the reason im asking is my new exhaust will likely be using one of those brackets so if all rearsets use the footpegs im out of luck. unless i want to start fabbing
