Reasons for poor MPG?
Discussion in 'Hangout Lounge' started by mrhuba, Apr 24, 2011.
  1. mrhuba
    mrhuba New Member
    Fullerton
    What would be the reasons a bike would get poor MPG?
    This would be a factor of things Im sure!
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    heavy handed driving.
  3. mrhuba
    mrhuba New Member
    Fullerton
    Aha shit...
    Whatta bout old oil??
    Cause I was driving pretty hard lately...
    Haha
  4. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    High float levels
  5. mrhuba
    mrhuba New Member
    Fullerton
    Hmm i seeee...
    Ok ok.
    Ima check mine out tommorow then.
  6. cutlass79500
    lawrenceville georgia
    flat tires, burnt valves, carbs out of sync, sticking calipers, Large women on the back lol
  7. macros10
    macros10 Member
    Newport News, Virginia
    Lmao Cutlass! Liked that one! Large women and flat tires are kind of synonymous, he he!
  8. cutlass79500
    all kidding aside no one mentioned a dirty air filter. or a vac leak
  9. BlkMage
    BlkMage Member
    Stead, NV
    Anyone selling a higher capacity fuel tank?
  10. waldo
    waldo Member
    San Jose, Ca. 95125
    What is your fuel mileage and is it called kilometerage in other parts of the world? Broken brake shoe springs, improperly adjusted brake shoes, stuck calipers, un-tuned engine (that includes everything from the air filter to the valve adjustment) oh and a" large woman on back" for sure, bad wheel bearings, uncalibrated odometer, wrong size front tire/wheel, wrong speedometer
  11. mrhuba
    mrhuba New Member
    Fullerton
    April 21, last thursday I filled up with 87 fuel at chevron for $4.21 a gallon.
    I put 2.45 gallongs of gas for $10.34
    -my millage reading 60 at this point
    then strangely I had to fill up again on April 23, on the last saturday.
    with 87 again and for $4.23 a gallon.
    -my millage read 131 at this point
    this easter Im at 154 miles and i belive half tanking it?
    So Im sure my millage could be MUCH better, I do need a carb cleaning and oil change for sure...
    those would drastically help my MPG right?
  12. bigfitz52
    You've really given us nothing to go on.
    What bike? Mileage varies; I generally get ~52mpg with the 550s.
    Valve adjustment, float levels, carb sync needing to be done can and will affect fuel economy.
    As well as everything listed above; low tire pressure, dragging brakes, etc., but those are relatively obvious.
    It's a four-cylinder bike; so you've got four little gas consumers there all wanting to fight with each other until you get them all on the same page. If they're fighting and not cooperating, they use a lot more fuel.
  13. TIMEtoRIDE
    One member noticed a mileage increase after losing the stock mufflers . . .which may have been plugged with rust and carbon.
    I got 42 MPG driving reeeally fast (80-105) with my 750.
    It gets 46 at exactly 60 MPH.
  14. mlew
    mlew Well-Known Member
    Apex, NC
    I've had problems with the fuel enrichment(Choke) not sealing. It has been the #1 reason on my bike when the mileage drops off. Black plugs is the first sign.
    My XJ and XS 1100 both average 35 mpg, 45 on the highway.
