Relocating front turn signals, Brackets?
Discussion in 'XJ Modifications' started by Shanesajda, Jun 10, 2015.
  1. Shanesajda
    Shanesajda Member
    southbury ct
    I bought some aftermarket turn signals for my xj750, anyone have any ideas on mounting them? I cant find a lot of options for buying mounting brackets for my forks (which i believe are 36mm). They all seem to be bigger than that. If anyone has any ideas please let me know
  2. jhicks
    jhicks New Member
    Houma Louisiana
    Maybe you could modify your factory brackets to fit the turn signals.
  3. k-moe
    The factory brackets mount to the forks via the lower clamp pinch bolts. You can make a bracket to fit your new signals to the same bolts.
  4. Shanesajda
    Shanesajda Member
    southbury ct
    ok so basically replace one of the 2 pinch bolts with the new signals? But that would mean the signal threads will have to be the same size as those factory pinch bolts correct? which i would assume is unlikely, we'll see.
  5. Shanesajda
    Shanesajda Member
    southbury ct
    and I know ill have to cut off the old signal mounts because they have a little shaft thing that sticks off an inch or 2 with a rubber boot that slips over
  6. Shanesajda
    Shanesajda Member
    southbury ct
  7. Shanesajda
    Shanesajda Member
    southbury ct
    oh @k-moe i misunderstood you, I know exactly what you mean. They dont have to thread into those bolt holes, the bracket gets screwed in with those pinch bolts and ill have a new hole for my lights above or below that, if i got you correctly. ill make something up. Ive already made a ton of brackets for this bike for aftermarket lights, gauges, etc.. so it should be cake now
    Good Idea thanks
  8. k-moe
    Exactly. You pull the pinch bolts to remove the Yamaha bracket, and use them to mount your new DYI bracket.
  9. Shanesajda
    Shanesajda Member
    southbury ct
    Made these today. Bottom 2 holes for the pinch bolts. And the signal right above
