removing rusted bolts and nuts
Discussion in 'Hangout Lounge' started by tabaka45, Nov 29, 2016.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Anyone ever tried this? I haven't had a chance but I'm not sure I believe that it works as easily as he demonstrates.
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Tried what?
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  4. tabaka45
    Brunswick, Georgia
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    sure - KMoe has been talking about that for a bit here and there. I have yet to try it - but heck; why wouldn"t ya?
    Kroil is great but overspray . . . . I'm going for the candle next time. Or maybe just grab some beeswax from some extra frames we have . . .
  6. TheCrazyGnat
    Central PA
    I've successfully used this method (although I actually did use a torch) for a few bolts here and there, and even a stuck jet. I don't necessarily recommend using it on your jets though, since then you have to get melted wax out of there...
  7. k-moe
    Yep. That trick is about 200 years old.
    hogfiddles likes this.
  8. hogfiddles
    Used it a lot myself
  9. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    I've heard a 50/50 mix of acetone and trans fluid works great ????
  10. k-moe
    It does.
  11. Stumplifter
    near Irma, WI
    Replying to myself is kind weird . . . . The other day I had to replace the gasket on my tractor exhaust. Heated the rusty nuts grabbed a chunk of paraffin, touched it to them, watched it wick in and things loosened up super easy.
    Unfortunately you need space and non-flammable surroundings to make this happen - as I eye up freeing the rusty fasteners holding the radiator/ fan cowl on the wife's jeep.
  12. k-moe
    @Stumplifter You can use a heat gun instead of a torch.
    Stumplifter likes this.
  13. NSchultz
    NSchultz Member
    Phoenix, AZ
    will this work on a broken bolt as well?
  14. k-moe
    That depends. Broken how, broken where?
    Got pics?
  15. NSchultz
    NSchultz Member
    Phoenix, AZ
    as requested....i put them in my build thread also. 3 of my 8 carb joint bolts broke when I was removing the carb......
  16. k-moe
    NSchultz likes this.
