Removing speedometer needle from XJ600 Diversion
Discussion in 'XJ Technical Chat' started by KoebbenXJ600, May 5, 2018.
  1. KoebbenXJ600
    KoebbenXJ600 New Member
    Denmark
    As topic says... :)
    I have to relplace my speedo needle on my Xj 600 Diversion from 1999, since it's broken.
    But how do I get it off? It's really stuck. I have tried to pull it up straight with a fork, flat screwdriver and of course my fingers - but it wont move. I'm afraid to brake something if I try to hard - witch I will say that I already did.
    Any suggestions?
    you don't remove it the needle has a plastic base molded onto a brass knurl . forcing the knurl can damage the internals of the speedo.
    forcing one back on same issue
    you can glue a tooth pick on it and paint it orange or if there is enough of the needle left on there you can try a tube from carb spray.
    https://www.hipoparts.com/fluorescent-speedo-gauge-needle-restoration-paint/
  3. KoebbenXJ600
    Denmark
    Really? Then I should stop now before I create any damage... Thanks anyway! ;)
  4. XJ550H
    yes I have done that as well as many others while searching for replacment speedos.
  5. XJ550H
    you could try cutting of plastic and refitting a good needle that you have removed knurll from but getting needle back on in proper position can be a chore.
    if not placed exactly your speedo will be off
