Replacement key
Discussion in 'XJ Technical Chat' started by KA1J, Sep 8, 2011.
  1. KA1J
    KA1J Member
    Groton, CT
    My original key is worn and copies from it are not so good.
    Is it possible to buy an original key, one which has the original numbers on it? Or is having a locksmith cut a blank from that original # as good as it gets?
    If I need to call a locksmith, do they have conversion info to use the # to make the cuts from or do I need to get that done by Yamaha?
  2. MiCarl
    Yamaha will not sell you a cut key unless you're buying it with the lock set.
    Key men (http://www.key-men.com) can cut you keys from the code.
    Not sure if your local locksmith can do it, but it's free to ask.
  3. doc2029
    doc2029 Member
    Richmond, Va
    I just sent an email request to get three keys made for my 82 XJ650-J we'll see what they say!
  4. bigfitz52
    Things to know about Yamaha keys:
    There are (5) different key blanks.
    The "number code" is generally on a label on the bottom (or bottom front if you're lucky) of the ignition switch assembly.
    Most professional locksmiths can make you new keys no sweat. They might even be able to figure out from your worn key what you need without the number.
    Bringing your own key blanks will irritate a good professional locksmith because he already HAS all five blanks. (Ask me how I found his out.)
  5. doc2029
    doc2029 Member
    Richmond, Va
    I have an original key with the code stamped in to the key. Thought I had lost my key about a week ago and after that terrifying experience I want a couple of spares.
  6. bigfitz52
    Seems like every used bike I've ever bought came with ONE key.
    One of the first things I do is get spares made.
  7. doc2029
    doc2029 Member
    Richmond, Va
    Yeah I was going to do it when I first got the bike but then put it off. Thinking I had lost the key made me wake up and say gotta get some keys made. That way I can put one in my under the seat tray, put in the baggie with my registration (copy) and insurance (copy) card. Then give my wife one. So if I lose the one on my key ring I'll be OK.
  8. Altus
    Altus Active Member
    London, Ontario
    Here's a good resource for finding the right key blanks for motorcycles/atvs
    Illco Keys for Motorcycles
    I've also found a certain Nissan key is a functional replacement - I've got one myself. I'll be buggered if I can remember the blank number though - I'll keep looking.
  9. doc2029
    doc2029 Member
    Richmond, Va
    I did order keys from the key-men.com site. Once they arrive and I have a chance to insure they were cut right and work I'll let you know my review of them. It seems that indeed they can cut keys from the code on the key... I guess I'll find out in a few days... They keys were ordered Saturday and they are on their way...
  10. MiGhost
    MiGhost Well-Known Member
    Worst Case in absence of a key code:
    You can take the key tumbler to any locksmith and they will be able to figure out the proper key cut needed.
    Ghost
  11. doc2029
    doc2029 Member
    Richmond, Va
    OK I got my keys from Key-men.com and they were on the money. Granted, I have an original key with the code stamped in to it so they knew how to cut it. All in all not too bad priced, I ordered two keys, so now I have 3. Gave one to my wife to put on her keyring and I'll hide one on the bike. Just in case I loose the original key on a long ride or something.
  12. pbjman
    pbjman Member
    Algonac, MI
    My bro lost the key for his Nighthawk. So he rolled the bike on his trailer and took it to a local locksmith. Guy comes out with some lockpicks and feelers, pokes around inside the lock a bit, goes back in and comes out in a few minutes with a key that he made. It didn't work on the first try, but he only needed to test it once and went back in for a quick touch-up. He made the key just by 'feeling' the tumblers and then cutting a key to work. Time was less than 10 minutes and cost was $50.
    This is as told by my brother...would have been kind of cool to see the guy work his skillz!
  13. raymondsmith
    raymondsmith New Member
    USA
    Dealer will always sell the set of the keys and they don't cut keys for vehicle.For such problems, Contacting the Locksmith is the prominent solution to the problem. They can make you new key from blank keys.
  14. k-moe
    The dealer I go to cuts keys. A locksmith is cheaper though.
  15. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    If you lose your keys you just need to get the number from the owners manual. There is a place to write it in on the first page. It has been 30 years so most of us will probably have forgotten doing this when we first brought our bikes home from the dealership.
  16. k-moe
    Almost none of the bikes will have the original owner's manual with them anymore. Thankfully the key code is stamped into the underside of the ignition switch, which most of the bikes still have with them.
    There are already better threads about this issue. Can we please let this one die again.
  17. Cafe_Guy94
    Cafe_Guy94 Member
    Ridgecrest, CA
    Which keys did you order? I'm trying to get some for mine as well. Did they work out?
  18. k-moe
    doc2029 hasn't been on in 6 years.
