replacing fuse box
Discussion in 'XJ Technical Chat' started by bikerdave, May 16, 2007.
  1. bikerdave
    bikerdave New Member
    new brunswick
    I read on this forum about a place on line you can order blade type fuse box for an xj 650. I cannot find the site or the discussion it was mentioned in . Does anyone know what this site may be?
    Dave
  2. Altus
    Altus Active Member
    London, Ontario
    Here's a good site with a good example:
    ATO fuse blocks
    You want the "6 Circuit ATO/ATC Fuse Block"
    Those prices are pretty good, but you can find similar or the same fuse blocks all over online.
  3. gremlin484
    gremlin484 Member
    Omaha, Nebraska
    I bought a 4 fuse block from Radio Shack that fit with very little modification.
  4. MiCarl
    Parts drawers, far right stack. 3rd drawer from the bottom. Unless you go to the mall where they don't have them.
    LINK
    Please don't ask how I know this.
  5. Stinky
    Stinky Member
    Flagstaff, Arizona
    I've seen em at Checker/Autozone type stores as well. Usually on the isle with all the replacement bulbs.
  6. gremlin484
    gremlin484 Member
    Omaha, Nebraska
    Thats it. I had to go to two stores to find it.
    Just call them. They should be able to tell you where the closest store that has one is to you.
  7. MiCarl
    Actually, if you click the link there is a button on the page to find it at a store near you.
    RadioShack does not carry a blade type block. I used their weatherproof inline mini blade holders on mine.
  8. bikerdave
    new brunswick
    Thanks for the advice, I ordered the ATO fuse box and will let every one know how it works
    Dave
  9. boostedsupra
    boostedsupra New Member
    stockton, calif
    the ato fuse bpx works and looks nice as well, sure beats the ugly glass fuses that just corrode anyways :)
  10. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I think the ATO or the RadioShack one will work better. I replaced mine this morning with one from wirewerks:
    http://wirewerksperformance.com/index.p ... ducts_id=1
    Works great and looks gooood but the seat won't fit with the cover on it. So I had to leave the top cover off. Wish I could post some pics. :(
