Replacing Handlebar
Discussion in 'XJ Technical Chat' started by dandrewk, Nov 15, 2007.
  1. dandrewk
    dandrewk Member
    San Rafael, CA
    A PO replaced the handlebars on my Maxim with low profile (Seca) ones. Unfortunately, he didn't replace anything else, which has led to a very un-level master brake cylinder and all sorts of difficulties with the angle of the rear view mirrors. And I HATE those fat, spongy grips.
    At this point, it would be far cheaper for me to just put back the original, semi-high risers. I've seen them used for around $35.
    I've never done a handlebar swap. It looks pretty straight forward - pull off the brake/clutch assemblies and the switches. Then it's four bolts.
    Anything I should be aware of?
  2. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    I would watch for the cable lengths... In case they replaced them with shorter ones... I would like to try drag bars on my Maxin... Just not sure how it would look yet
  3. Robert
    I love the fat spongy grips, swap perchance?
  4. dandrewk
    dandrewk Member
    San Rafael, CA
    The grips or the handlebars? :)
    The grips are glued on. Only way to get them off is with an Xacto blade.
