restart a rebuild
Discussion in 'XJ Technical Chat' started by Door dude, Apr 10, 2019.
  1. Door dude
    Door dude Active Member Premium Member
    Mountain Home Arkansas
    Okay, iv'e got my engine back together after top end rebuild and powder coating. I need information on the best way on a restart. Any one have a good way ?
  2. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    A restart as far as what?
  3. XJ550H
    you could rotate motor several times by hand to get the oil pumping through the motor
    if you do this with the valve cover off you will see the flow into the cam shim area.
    when you get it running for a few minites stop and check the oil level
    Timbox and 1965soda like this.
  4. Door dude
    Sorry, an 82 xj 750j max. I preloaded the valve area with fresh oil. I figured that doing it by hand was the first step, i was wondering if i should do this with the spark plugs in or out? Will oil pump correctly with the plugs out?
  5. Ryengoth
    Wilmington, NC
    Assembly lube is ideal for dry restarts on all bearing surfaces. I would be concerned that all of the aluminum journals will be dry and cause galling. Is that not a concern on these bike engines?
    1965soda, k-moe and Door dude like this.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Anytime I start a motor after I pull a head I generally:
    - Spin slowly by hand with plugs out. Check for correct cam timing.
    - Spin with starter, plugs out and valve cover off until I get oil up top. Cans are usually installed with red assembly lube.
    - Start up as normal.
    - Tune, let cool, re torque head.
  7. Door dude
    Good call on that, and i did use assembly lube there and the cylinder walls. Thanks for the info on the re torque
  8. k-moe
    If you used assembly lube then just prime the carbs and start the engine.
    Franz and Ryengoth like this.
  9. Door dude
    I believe thats what i will do im pretty confident that she will start. Thanks for the help.
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Don't forget to cross your fingers and hold your breath!
    1965soda likes this.
  11. k-moe
    I thought it was hold your fingers and cross your breath.
  12. MattiThundrrr
    That's for your Seca. He's working on a Max.
    1965soda, jayrodoh and k-moe like this.
  13. Door dude
    Any thoughts on the new break in period
  14. jayrodoh
    jayrodoh YimYam
    Cleveland
    Just a head rebuild or did you do rings etc?
  15. Ryengoth
    Wilmington, NC
    Good question, I'll be reseating the rings on my 550 after cleaning and de-glazing the liners.
  16. Door dude
    I re ringed and deglazed, cleaned, replaced gaskets, o-rings, dowel pins.
  17. Ryengoth
    Wilmington, NC
    How many miles are on the engine? Any reason you decided to spend on new rings? I am going to re-use the rings in mine, 18k miles and the bores looked good. I haven't measured the bore taper yet, though. It fired OK and there are no signs of blow-by so I'm not dumping the value of the bike into a set of rings just yet.
  18. Door dude
    16 k I just figured that I've got it apart why not.
  19. XJ550H
    do it now or do it later. another thing you will not have to think about.
  20. jayrodoh
    jayrodoh YimYam
    Cleveland
    Kinda like asking ten people how to use a cast iron pan, you'll probably get twelve answers.
    I don't have any XJ specific experience but this Wiseco page has a detailed procedure halfway down the page:
    http://blog.wiseco.com/proper-engine-break-in-after-a-rebuild
    Ryengoth and Door dude like this.
  21. Door dude
    Let me brake it down. I bought my 82 xj 750j max fall of 2016 i didn't get to ride it much. summer of 17 i got to ride a lot it felt great to get back to riding. in my mine it was a great running bike Spring of 18 i bought a 83 xj 750 midnight max with 35k the difference was night and day, pun intended. The midnight had no vibration, the only thing i felt was the bumps in the road. The 750 j i had a lot of engine vibration so i removed the engine replaced all of the motor mounts. I then decided to powder coat the jug section of the engine so i had to take the head apart... well you know the rest.
    jayrodoh likes this.
  22. k-moe
    Let her idle until warm, then ride the piss out of her.
    Just avoid running at a constant speed for a while. No 30 minute trips at a steady speed until you have a few hundered miles on the rings.
  23. Mototimothy8
    Mototimothy8 Member
    Lewisburg, PA
    Did your 750 have rubber mounts? My only grip is the buzz in my butt at 65-70mph. Otherwise the 750 is pretty smooth for not being rubber mounted.
  24. k-moe
    The Maxim 750 engine is rubber mounted.
    The "butt-buzz" can be tamed with a running synch of the carbs.
  25. Door dude
    All 6 rubber mounts have been replaced. Running synch was damn near spot on. It wasn't just butt buzz,... handle bars, & foot buzz. It just didn't ride like my midnight. I will let you all know if it repaired the problem. Thanks for all the help.
