Rev issue
Discussion in 'XJ Technical Chat' started by BhamXJ550, Sep 29, 2018.
  1. BhamXJ550
    BhamXJ550 Member
    Bellingham
    I have an ‘82 XJ550 Maxim that I’ve revently converted into a brat/cafe racer. After I swapped my bars I noticed that the bike has an issue where I pull the clutch in, it revs higher. Or if I come to a stop and put the bike in neutral, the rpms stay at around 3-3500, and come down to idle rev after 30-45 seconds. Another problem I’m having is if I rev the throttle for a quick second it hovers around 3 grand for about 5 seconds and then comes down to idle. Help!
  2. Taylo105
    Taylo105 Active Member
    San Diego CA
    stuck throttle cable. If the only change you made to your bike was the bars, then you have an issue with the cable sticking, or the throttle tube getting stuck.
    Completely remove the throttle cable from the carb. Let the bike idle without the cable connected the with your finger engage the throttle to see if the issue still occurs. If so, you then need to add extra slack to your cable and/or lube it
  3. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Alternatively, the clutch isnt disengaging all the way, again an adjustment issue, or the cables are too tight, or routed wrong with a sharp bend in them causing them to hang up /stick.
  4. Taylo105
    San Diego CA
    also, do you have the stock airbox behind those side cover? Or did you switch to pod filters?
  5. BhamXJ550
    BhamXJ550 Member
    Bellingham
    Yup all stock, switching those out for number plates this week though
