Wanted Rims for 85 maxim 700
Discussion in 'For Sale, Trade/Swap, Wanted' started by Colin 85 700, May 15, 2019.
  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    If the will fit, id like to get a set if the fancy curved spoke rims i see on so many earlier XJ models.
    Anyone here in Ontario would be great!
    Id be willing to trade / part trade my originals if you want them.
    Side note: can anyone give me a quick list of what bikes interchange?
    Thanks!
  2. joe elliff
    joe elliff Active Member Premium Member
    illinois
    I have a set but I’m in USA. Crap. Edited response now I have original 85 maxim rims too. Or early xj rims
  3. xtmag
    xtmag Member
    Rochester, MA
    I have a set of rims from a 1982 Xj750 maxim. Not sure about fitment though. I am in Massachusetts.
  4. XJ550H
    info over load covers rims
  5. Colin 85 700
    Thunder Bay, ON
    I cant get info overload to load... Lol! On my shitty i pad, can anyone give me a copy n paste of what fits my bike please and thanks! :)
  6. xtmag
    xtmag Member
    Rochester, MA
    Front Wheels:
    NOTE: please note that the reference to "interchange" is used loosely: there may be differences in appearance (wheel style) as well as wheel size (diameter and/or width), as well as axle fitment, speedometer drive gear fitment, and brake disc attachment (and thus brake rotor type).
    OEM front WHEEL # 4U8-25168-00-00
    - straight 5-spoke design, aluminum wheel with polished rim and natural-finish spokes with low gloss black painted trim
    - size: 1.85 x 19"
    - used on: XJ550 Seca models
    - will interchange with......unknown. The speedometer drive gear unit is unique to this model, but is shares the same axle and bearings as all XJ550 - XJ900 model wheels.
    OEM front WHEEL # 4H7-25168-20-98
    - 10 spokes (5 sets of 2) "dual-spiral" design, aluminum wheel with polished rim and natural-finish spokes with low-gloss black painted trim
    - size: 1.85 x 19"
    - used on: XJ550 Maxim, XJ650 Maxim and XJ650RJ Seca, and all 1981-83 XJ750 Maxim and Seca models
    - will interchange with Midnight Maxim wheel below.
    OEM front WHEEL # 4H7-25168-20-8L
    - 10 spokes (5 sets of 2) "dual-spiral" design, aluminum wheel with polished rim and natural-finish spokes with nebular gold painted trim
    - size: 1.85 x 19"
    - used on : XJ650 Midnight Maxim and XJ750 Midnight Maxim models
    - will interchange with standard Maxim wheel above.
    OEM front WHEEL # 16G-25168-29-4N
    - angled "straight" quad-spoke design, aluminum wheel with polished rim and natural-finish spokes with silver painted trim
    - size: 1.85 x 19"
    - used on: XJ650 Turbo
    - may interchange with the # 4H7-25168-20-98 or # 4H7-25168-20-8L wheels above.
    OEM front WHEEL # 42H-25168-00-98
    - size: 2.15 x 19"
    - used on: all XJ700 and XJ750-X models
    - will interchange with....nothing else, without a lot of experimenting and/or fabricating. Axles shaft and speedometer drive gear unit are unique to this model.
    OEM front WHEEL 31E-25168-20-98
    - angled "straight" tri-spoke design, aluminum wheel with polished rim and natural-finish spokes with low-gloss black painted trim
    - size: 2.15 x 18"
    - used on: FJ600, XJ750RL, and XJ900RK, RL, N, and FN models
    - will interchange with #31E-25168-00-WG below.
    OEM front WHEEL # 31E-25168-00-WG
    - angled "straight" tri-spoke design, aluminum wheel with polished rim and natural-finish spokes with hi-tech silver painted trim
    - size: 2.15 x 18"
    - used on: XJ900 F models
    - will interchange with #31E-25168-20-98 above
    OEM front WHEEL # 4W1-25168-20-98
    - 10 spokes (5 sets of 2) "dual-spiral" design, natural-finish aluminum with low-gloss black painted trim
    - size: 1.85 x 19"
    - used on: XJ1100 models
    Rear Wheels:
    OEM rear WHEEL # 5K5-25338-20-00
    - size: 3.00 x 16"
    - used on: XJ550 Maxim models
    - will interchange with XJ550 Seca models, but uses a larger diameter brake drum and shoes. Will not interchange with any of the larger cc XJ-series bikes.
    NOTE: service manual specs says this wheel is 18" diameter but that is wrong!
    OEM rear WHEEL # 4U8-25338-20-00
    - size: 2.15 x 18"
    - will interchange with XJ550 Maxim wheel, but uses a smaller diameter brake drum and shoes. Will not interchange with any of the larger cc XJ-series bikes.
    OEM rear WHEEL # 4H7-25338-20-98
    - size: 3.00 x 16"
    - used on : XJ650 Maxim models
    - will interchange with XJ650 Midnight Maxim wheel below.
    NOTE: smaller diameter brake drum than XJ650RJ Seca, XJ650 Turbo, and all XJ700 and XJ750 model wheels.
    OEM rear WHEEL # 4H7-25338-20-8L
    - 10 spokes (5 sets of 2) "dual-spiral" design, natural-finish aluminum with nebular gold painted trim
    - size: 3.00 x 16"
    - used on : XJ650 Midnight Maxim models
    - will interchange with XJ650 Maxim wheel above
    OEM rear WHEEL # 16G-25338-21-4N
    - size: 2.15 x 18"
    - used on: 1982 XJ650 Turbo
    - will interchange with 1983 XJ650 Turbo wheel below; differs only in the painted trim color. Can also be used on all XJ650 Seca and XJ750 model bikes (except XJ750RL) and differs only in size and appearance. Can also be used on XJ650 Maxim and Midnight Maxim models, and has a larger diameter rear brake drum and shoes.
    OEM rear WHEEL # 16G-25338-29-4N
    - size: 2.15 x 18"
    - used on: 1983 XJ650 Turbo
    - will interchange with 1982 XJ650 Turbo wheel above; differs only in the painted trim color. Can also be used on all XJ650 Seca and XJ750 model bikes (except XJ750RL) and differs only in size and appearance. Can also be used on XJ650 Maxim and Midnight Maxim models, and has a larger diameter rear brake drum and shoes.
    OEM rear WHEEL # 1FG-25338-20-98
    - size: 3.00 x 16"
    - used on: XJ700 non-X models
    - will interchange with XJ700-X wheel below, and with all XJ650 Seca, XJ650 Turbo, and XJ750 model bikes (except XJ750RL) and differs only in size and appearance. Can also be used on XJ650 Maxim and Midnight Maxim models, and has a larger diameter rear brake drum and shoes.
    OEM rear WHEEL # 1AA-25338-00-98
    - solid center hub with cutouts to resemble a 5 "spoke" design. Aluminum wheel with a natural finish on the on left side, and a low-gloss black finish on the right side
    - size: 3.00 x 16"
    - used on: XJ700-X and XJ750-X models
    - will interchange with XJ700 non-X wheel above, and with all XJ650 Seca, XJ650 Turbo, and XJ750 model wheels (except XJ750RL) and differs only in size and appearance. Can also be used on XJ650 Maxim and Midnight Maxim models, and has a larger diameter rear brake drum and shoes.
    NOTE: larger diameter brake drum than XJ650 Maxim and Midnight Maxim model wheels, same size brake drum as XJ700 and all other XJ750 model wheels.
    OEM rear WHEEL # 5G2-25338-29-98
    - 10 spokes (5 sets of 2) "dual-spiral" design, aluminum wheel with polished rim and natural-finish spokes with low gloss black painted trim
    - size: 2.15 x 18"
    used on: XJ650 Seca and XJ750 Seca models (except XJ750RL models)
    - will interchange with all XJ700 and XJ750 model wheels (except XJ750RL) and differs only in size and appearance. Can also be used on XJ650 Maxim and Midnight Maxim models, and has a larger diameter rear brake drum and shoes.
    OEM rear WHEEL # 10L-25338-20-98
    - size: 3.00 x 16"
    - used on: XJ750 Maxim
    - will interchange with XJ750 Midnight Maxim wheel below, and with all XJ700 and XJ750 model wheels (except XJ750RL) and differs only in size and appearance.
    OEM rear WHEEL # 10L-25338-20-8L
    - size: 3.00 x 16"
    - used on : XJ750 Midnight Maxim models
    - will interchange with XJ750 Maxim wheel above, and with all XJ700 and XJ750 model wheels (except XJ750RL) and differs only in size and appearance.
    OEM rear WHEEL # 31E-25338-20-98
    - size: 2.75 x 18"
    - used on: XJ750RL and XJ900RK, RL, N, and FN models rear
    - will interchange with #31E-25338-20-WG below
    OEM rear WHEEL # 31E-25338-20-WG
    - angled "straight" tri-spoke design, aluminum wheel with polished rim and natural-finish spokes with high-tech silver painted trim
    - size: 2.75 x 18"
    - used on: XJ900 F model rear
    - will interchange with #31E-25338-20-98 above
    OEM rear WHEEL # 4W1-W2533-20-98
    - size: 3.00 x 16"
    - used on: XJ1100 rear
    - although it looks similar to the spiral-design wheels used on other models, the wheel bearing sizes, arrangement, and lack of rear brake drum makes this wheel unique.
    Colin 85 700 likes this.
  7. Colin 85 700
    Thunder Bay, ON
    Thanks xtmag.. Guess in stuck with stock :)
  8. Colin 85 700
    Thunder Bay, ON
    If i do a burnout, and simultaneously heated the rim spokes with a torch... Do you think theyd bend all curvy and cool?
    Like the 83 rims i want? ;) Lol! If icould get a free set id experiment but oh well.
  9. Colin 85 700
    Thunder Bay, ON
    For the front i could superheat the spokes then drive down the road and jam the brakes on to curve em? ;)
