RPM issue
Discussion in 'XJ Technical Chat' started by BhamXJ550, May 15, 2020.
Tags:
  1. BhamXJ550
    BhamXJ550 Member
    Bellingham
    I’ve noticed while riding my 82 XJ550 maxim the rpms do not decrease when I pull the clutch lever in. In fact, they actually increase. Any ideas?
  2. JBurch
    JBurch Active Member
    Owego, NY
    Let up on the throttle...........
  3. BhamXJ550
    BhamXJ550 Member
    Bellingham
    I do
  4. XJ550H
    Check throttle cable routing. Check to make sure your throttle cable is adjusted properly it should be a tiny bit of slack. Check to make sure your throttle cable is lubed. And check that your idol is set properly.
    If none of those things work have you sync the carbs? And you probably want to check for vacuum leaks.
    Rusty81 likes this.
  5. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    Check throttle cable is returning to idle at carbs. Lube if necessary.
